NJMike
Hi Jerry
I see youre in Randolph, Im just down route 10 in East Hanover. My Mach 1 is currently at Performance Ford for the mods in my signature. While I cant comment on the Whipple yet, I can say I had a 2014 GT with a Roush and some other upgrades making 600 whp. My two recommendations are as others have mentioned, tires #1. Whatever you go with you'll need a DR compound tire. I was running 315/30/20 Nitto NT05DR, which is very similar to the 555 II. Definitely get yourself 11" rear wheels to help put it down. The other #2 item is gears. I had 3.73 which pretty much lit up the tires through second. If you retain the 3.73 you'll have to modulate the power via your right foot. When I geared down to 3.27 (I cant remember the exact ration, it may been 3.31) the power applied a lot better in first and second. This coupled with the 20's (stock was 19) making the tire a bit taller, had my final ratio around 3.15 or so.
With the kits you're considering, you'll be in the 700-800 range, you'll need help putting it down
