Belly pan removal with HP splitter
Rob_R
Virginia
Robert
SPF Cobra, 26 Jeep Moab 392, 24 Power Wagon, 88 Jeep YJ
Rob_R
Virginia
Robert
There's a aftermarket k member brace I want to install along with some led turn signals.
I don't know if getting to the turn signal lights requires bumper removal. If changing the turn signal bulbs doesn't require removal of the bumper, then it is far easier to remove the lower splitter and then remove the belly pan as I outlined above.
I think trying to pull the bumper with the belly pan attached will lead to unwanted damage.
Also, have you checked if the new K member requires belly pan modifications to fit?
MACHtobers Very Own
MACHtobers Very Own
Hampton Roads, Virginia
2022 Mustang MACH 1
Yeah i knew with the turn signal front bumper may not need removal but the brace was a definite. Company confirmed fitment on that. Based on this thread was just trying to avoid drilling out the splitter.
MAGS1
Somewhere in Middle America
Mark
2022 Mustang GT
I assume the turn signal housing on the Mach is similar to the GT, you do need to remove the bumper to get to the housing. Here’s a CJPP video
MACHtobers Very Own
MACHtobers Very Own
2022 Mustang MACH 1
In order to do an LED turn signal upgrade you have to go with the upgrades that work for 15-17 Gt's/350's. i guess they had extra surplus and yes bumper has to come off.
Rob_R
Virginia
Robert
I learned something today.
Had no clue what you meant by creeper lol. I looked it up and it is a rolling stool which is pretty handy but at first I was like, ah nah I'm good - don't need no creepy dude helping me. :giggle:
I learned something new also! I'm a retired old cuss and I have 3 creepers and 1 rolling stool that I have collected in the last 45 years. I never knew the word creeper morphed from the lay flat on the ground rollers to creeper stools, engine bay creepers, and interior creepers. What a world!
Rob_R
Virginia
Robert
Ah, I get it. It is not hard to drill out the plastic rivets. There are a couple of aluminum rivets on the bottom of the lower splitter - Don't remove those!
If space is limited you can use a 90° drill and a small ~1/8" drill bit. Then use a clip tool to pop them out. Or you could try a something like a small ~1/8" punch and hammer to knock the pin out. Drilling will be easier and faster.
John S
Novi, Michigan
2022 Mach 1 HP
For me, bumper removal with the the HP lower splitter and belly pan attached is easier than bothering with seperating the individule pieces. Just be careful around the headlights and the top corner tabs and support the pan so everything slides out as a complete module. The 2018+ bumper to fender attachments are easily accessed from the engine compartment with a long extension or from the fender well by separating the splash shield from the fender.
MAGS1
Mark
2022 Mustang GT
CJPP has a video for the 15-17 cars too, although I assume the process is very similar. Just the actual lights that are different
Mikepol2
Pittsburgh, PA
2021 Mach 1, 2019 Ram 1500
wingnutt
@FL410
michael
350R Procharged w/P1X
lol…anyone who has a car with a belly pan should pull it (with the bumper) at least once in their life, just sayin 🤓
23GreenGremlin
Mechanicsburg, PA
2023 Mustang Mach 1, P0389, Eruption Green, "Gremlin"
MAGS1
Mark
2022 Mustang GT
It’s a great life lesson (as we tell our kids seemingly daily LOL)
