Auto Trans Temperature
Xavierviana
Curacao
Mustang gt premium 2015
Is this normal Transmission (Auto) Temperature?
Maximum temp Range: 93-105 degrees C (200-221 F)
Normal-Spirited driving
City drive and long roads (no highway) (island)
Outside temp: 28-30 degrees C (82-86 F)
Whats the Max temp for a Normal range?
Thanks.
XV
ahl395
Allan
Normal/spirited driving mine is usually between 195-205, I've only seen it higher than 205 during long WOT pulls. Driving lightly it will stay under 190 for a long time
boB
boB
2019 GT PP1
Assuming the transmission oil is routed through the radiator (don't know if this is so but it has been done this way for ages) it would run close to coolant thermostat temperature.
ahl395
Allan
No, our cars have a dedicated transmission cooler. Mounted between the condenser and radiator.
boB
boB
2019 GT PP1
Interesting, maybe testing showed that worked better than the radiator type? I ordered a 6 speed, probably no cooler on that. ;)
69mach1-395
central nm, usa
2016 RR GT/CS
It could have both type of coolers...
ahl395
Allan
Phoenix
Instagram: PhoenixNFA
Central Texas
2016 GT350 Tech AvGrey/Black Stripes
i remember my trans temp being above 200 most of the time. youre probably fine. if it gets above 220F, back off.
Zinc03svt
usa
stang
200-220 perfectly normal. 265 or higher it is getting into hot range.
Jay-rod427
Kansas
2016 GT C/S
As far as I remember seeing the trans has an internal thermostat that won't even circulate fluid to the cooler until 190. I see around 200 typically, 205-210 running 80+ down the highway in the summertime.
CVCashmere
South Jersey
Carl
15 GT Vert w/Steeda lower brace, PP sways & susp
205 on traffic day in the Summer.
CVCAshmere
So here’s my input for today (Jan 31):
2018 EB w/PP
10R80
Outside Temp: 7*
Drive time: 1.5hr
Speed: 60-65mph
Trans gear: 10th
Trans Temp: 100*
The trans temp remained at 100* during the entire drive. Once I got into stop/go traffic (towards end of drive), the temp only went up to 135*.
Sitting idle for 10mins now, it has gone up to 153*, with exterior temp now being 10*.
69mach1-395
central nm, usa
2016 RR GT/CS
^ that would be consistent with having only an external cooler and not the kind that also goes thru the radiator...
Xavierviana
Curacao
2018 EB w/PP
10R80
Outside Temp: 7*
Drive time: 1.5hr
Speed: 60-65mph
Trans gear: 10th
Trans Temp: 100*
Fahrenheit or celsius? A bit confused here.
