Auto Transmission Oil Temperatures.
Jaxstang
Boynton Beach
2019 Mustang GT Premium
Hi guys, what should be the average oil temp on the auto transmission? I never had a car that could measure this before and looking at the temp it got to 200 degrees (ambient temp was 65 degrees if it matters) and kept going up but the trip was over. I'm going on a long trip in few weeks and I wonder how high should it go before I start to freak out :help:
dwaleke
Jeep
Engine oil should be around 212 degrees fully warmed up.
Trans oil should be a lot less.
TheGrayRider
Huh...
Arizona
15 GT PP Black
Perfectly fine, these automatics are designed to run at those temps..
Monster_Load
Houston, TX
Oxford White GT Premium, 2007 Tundra Limited
Checked mine yesterday and it stayed at 200 degrees also. I hope this is normal.
I called the service dept. and looked online but can't find what the normal operating temp is...
Mountain376
SE Michigan
'17 Camaro SS 1LE, '16 Camaro SS, '12 Mustang GT
It will typically run between 190-210F during normal use. Track use, I am not sure.
unintelligible
V1, VR, Gear Up!
Melbourne, FL
'15 GT Premium
The Ecoboost AT I rented was almost always at 201 degrees.
CAPRI RS
clayton nc
2015 gt 50th anniversary
My trans stayed @ 200/205 all day today..hope its normal. .only 600 miles on it.
69mach1-395
central nm, usa
2016 RR GT/CS
Is the factory fluid synthetic?
What is the recommended OCI?
redtrack
P.R.
2018 GT PP1 10AT
After reading this thread, I looked under the car at the transmission.
I found that there are 2 aluminum tubes from right side to the left side of the trans. The interesting part is that they are inches from the catalytics!
Then I wrap both tubes with thermo wrap tape used on headers. This afternoon I drove about 25 min. outside 89-90F, used in S, and the highest was 185F- 189F.
A simple mod, that looks to reduce trans temps.....
dwaleke
Jeep
Might be a good mod and might not be.
You want the transmission fluid to warm up as quickly as possible. That design might contribute to that (I don't know).
In a cold climate this might do more harm than good (or might not do anything at all).
redtrack
P.R.
2018 GT PP1 10AT
Maybe you are right in real cold weather, but heat is a trans enemy. Here our average temp is 85-95F, so keeping everything at lower temps is benefitial. Also maybe Im getting the benefit of my modified grill, since the trans oil cooler is in the radiator. The highest I have seen is 189F so far....
jasonstang
Denver, CO
2017 GB GT/CS 6MT
It's fall in the midwest around 40-60 and my ATF is at 145F.
