mustang_guy
- Jun 29, 2015
- United States
- it has an engine!
Longer oil changes can cause a lot of problems. It contributes to the seal issues bmws have. Longer then 5k service intervals is silly. Also no fluid holds viscosity for the lifetime of a vehicle. Its designed to fail and cause a new transmission to be bought. Bmw does it with all of their vehicles, including rear differentials. They calculate what the average life of typical ownership is and say its good for that amount of time. Not changing your transmission fluid because the manual says its okay is the dumbest thing ive read on a forum in awhile. Autos should be changed every 15-30k, based off how the car is driven as should rear differentials. You realize they are in this to make money, they will make more money from a new transmission being bought then shorter interval changes. They don't make jack from regular maintenance. Its repairs that bring in the money.Do you people not understand that the values listed in the owner's manual are arrived at by hundreds of engineers who have put thousands of hours into testing parts, fluids, assemblies, and hundreds of thousands of miles on vehicles?
Yes - the owners manual states 150K transmission fluid interval, for normal driving conditions. The transmission and transmission fluid is designed and engineered for this. Is it beneficial to do it sooner? Yes. Is it necessary? No.
Oil changes are now recommended at 10K.
Engines and transmissions are built now better than ever. Better materials, better design, tighter tolerances, all of that allows the longer duration.
The push for longer maintenance intervals comes from the consumer. Because, guess what, nobody likes taking their vehicle in for service.
As far as the lug nut torque, no, you will not warp, snap off, or seize anything. The product is DESIGNED for this, hence why the spec is what it is.
