Anyone Dyno, Has physically Seen, ESS System 800+RWHP?
ESSBoosted5.0
Queen Creek AZ
Shadd
2020 Mustang GT PP1
The g3 is already pushing like 900 whp with the 100mm pulley. So, a bigger unit with a small pulley should pass the 1k without problem
Everyone's car is different, I'm at 1000whp with my G3 on the 100mm pulley currently. Some guys barely break mid 800hp on the 100mm. The 105mm pulley got me 870whp. Anything below the 100mm pulley requires the G3x billet impeller.
Nawsad123
Everett
Bonez
2017 Mustang GT
Are you looking at going higher than that 1k goal?
At some point, yea. Need to do tranny woerk but woukd bd happy with 900 or so before building out the 6r80
Proshop
Billy
2021 Ford Mustang GT
If you were gonna stay around the 1k mark then I’d say G3x but if your thinking of going higher than go with the g4! It will give you the most room to grow at those levels.
Nawsad123
Everett
Bonez
2017 Mustang GT
Big reason why id go for the g4 is because of my lower compression motor which requires a couple more psi to make the same amount of power a stock compression motor would. Outside of that, anything above 1k would definitely need tranny work and a built shortlblock (aluminator has rods pistons arp bolts etc - max 1k hp from what i hear)
Exploded_Muffin
Houston, Texas
2021 GT500
You gained 130whp from the 105mm to 100mm pulley with no other changes?
Cory S
Bradford, NH
Cory
2016 Mustang GT Premium
TQ breaks transmissions. You’ll be fine with your centri.
wazslow
PA
2016 Mustang GT/CS
Dont go blind believing dyno numbers… go with 60-130 times and trap speeds… those tell you a more accurate numbers
Especially when guys dyno at high altitude with massive correction factors. Most of those numbers are inflated quite a bit.
SolarFlare
S. Fla
2015 CO GT
This. You ain’t gaining almost 150whp with one size down pulley, cuz injectors don’t do squat. So if everyone is at 850-870 on a setup and you make 1000 then you didn’t do anything new….you just got lied to and believed it.
hlfbkd420
SW 'Merica
Bilbo Hicks
2015 KIA Sorento SXL
I just wanted to say that this thread has been informative. Not just for the ESS talk either. May go with a centri after I blow up my 2nd motor.
ESSBoosted5.0
Queen Creek AZ
Shadd
2020 Mustang GT PP1
If you do decide to go ESS, hit me up on IG @ Sabotfit5oh. I'll get you squared away with everything you'll need for whatever power level you need šŸ’Æ
wingnutt
@FL410
michael
350R Procharged w/P1X
this, times eleventy…dyno means nothing, trap speeds are the real heartbreaker. Some of us learned this back when we were still using FMUā€˜s on our Kenne Bell blowersšŸ˜‰
Speeds8erM-1
Pcola Fl
Sold a bunch
Or use mustang dynos which have been the most inconsistent I've seen for the last 20 years. People always say "it was on a mustang dyno, it would make more on a Dynojet" when in reality the dynos that always come out as unusually high are mustang dynos.
mustang dynos have tons of input from dyno operator and suck. Dyno jet has been the industry standard for at least 25 years for a reason.
