Any planned modifications to your 350?
stanglife
Jeff
1993 Coyote Coupe
I like the OEM look but a little bit of a pain to check for oil in it.
M5944
Pittsburgh PA
2016 GT350 Base Race Red no Stripes
I do agree it looks like a pain to Check the oil level but it looks the best in my opinion plus it is $210 cheaper then the upr catch can. I would rather save the money.
CSL
WA
16 GT350
Glad you're liking the spring! :)
Do tell how this spring works specifically for the GT350 application when the 350 is not the same as the regular S550 with a dual spring assembly?
bdub85
MD
Bobby
2016 GT350 Track Package Shadow Black
You remove the GT350 dual spring and replace it with the single spring. It's pretty simple. I did it by hand without any tools.
Next step for me is tint, and I think I'm going to replace all the bushings.
CSL
WA
16 GT350
So the end result is one spring instead of two? I don't have my car yet to visually observe; do you have a pic of it installed on the 350 spring assembly?
bdub85
MD
Bobby
Yep. The whole assembly is the same as any other S550. The only difference with the GT350 is they add this middle piece and 2 springs instead of just 1 spring. You remove the white middle plastic piece and the 2 springs and replace it with the single Steeda spring.
CSL
WA
16 GT350
Great....thanks for the clarification. So how different is the feel? Can you give a before and after description?:cheers:
bdub85
MD
Bobby
Before: The clutch felt fine. I had no issues using the clutch, and I could drive the car smooth fine. The main thing about it was that it had a very numb feel which I think is caused by the strong stock springs. I couldn't feel the exact point where the clutch engages. The pedal felt the same all the way up from the floor.
After: The clutch feels a lot more linear meaning I feel exactly where the clutch starts to engage. It just feels like how a clutch should feel. Hard to really explain it.
Epiphany
Global
I like to disassemble things.
Did someone from Steeda assure you that the spring was fine for GT350 applications?
bdub85
MD
Bobby
It's a clutch helper spring. You can run without one if you wanted.
Epiphany
Global
I understand that as well as the reason for having one. I was only curious if anyone from Steeda commented to you that the single spring was acceptable in place of the twin spring assembly.
