Firsttexan
Get the best pads and use the money for lightweight forged wheels. I like the Baer discs. $1500 I think.
Great post!!!I have been toying with the idea of going with the GT350R brake kit though, honestly, it would wind up being the most irresponsible purchase I ever made given that the car may never see the tract. The forces pushing me towards this kit are:
1) The PP and Bullitt brake kits (same brakes/different colors) add a good amount of weight.
2) I have not seen any literature as to differential weight of the GT350R set-up.
3) The GT350 kit comes with beefier replacement half-shafts which is attractive given that I currently have 670HP at the crank and will be raising this, and will soon be putting on very grippy tires. This somewhat offsets the high cost of the brakes, themselves
3) I am not comfortable with other big brake kits such as from Baer and Wildwood, both for reasons of cost and reputation, and these kits seem to be far less complete than those offered by Ford Performance
4) I am not about flash (I would actually get the black caliper version of the GT350 kit) but, at the same time, I really do not like the look of the stock GT calipers and rotors, and, besides, the stock rotor design is heavy and poor at dissipating heat.
5) I am not sure about PowerStop-like solutions due to them not publishing their weight specs and uncertainty as to their durability and performance.
6) I do not like the look of hand painting the existing calipers
7) It makes no sense to me to have the exiting calipers powder coated; I would rather put that money toward the GT350R kit.
I just cannot bring myself to pull the trigger on a $4K brake modification....but I had no problem putting out that kind of money for the supercharger.....
Then what is the reason you want to upgrade them (nothing on that list was the actual reason). Ask yourself what is wrong with your current brakes that you want improve ?I have been toying with the idea of going with the GT350R brake kit though, honestly, it would wind up being the most irresponsible purchase I ever made given that the car may never see the tract.
My subjective experience of my brakes is that they have insufficient bite and that their application is not linear to pedal actuation. They are definitely inferior to the brakes on my previous cars (BMWs and Porsches), and their overall feel is dissatisfying relative to other aspects of the car which I have modified, namely the suspension, chassis and power.I am a firm believer of buying a car for what I am going to use it for, you said you are not going to do and track days I assume you mean HPDE/Open track days on a road course. The brakes on the GT will bring you to a stop on any drag strip or street situation you might encounter. I had a 2012 Mustang with the Brembo brakes package because I was doing track days but the standard brakes on any GT are IMO just as good as the 2012 Brembo brakes. The only difference in track brakes and street brakes is that track brakes can handle multiple hard braking without overheating. Probably half the guys going for the performance packages will never see any track time but the will have track cred at the car shows. My 2021 will never see any track days but I still like have the Coyote power even though I am pushing 80.
The problem is with the base inverted rotors. They don't cool well due to their design, and unfortunately the air deflectors won't do anything unless you get proper designed rotors which means doing the PP or GT350 upgrade.There might be cost-effective remedies such as replacing the pads, rotors and lines. Rotor and fluid grade replacement could also address concerns of heat dissipation. I already have air deflectors on the Steeda tension links.
I HATE grabby brakes. the forces should mount quickly as temps rise but that initial touch of pad to rotor should be smooth. I suspect a new set of rotors and pads and BROKEN IN PROPERLY will satisfy your needs. It's not like you're bombing into corner entry at a buck 10 anyhow. and doing it over and over and over mere 15 seconds apart.but the braking is very lackluster approaching the the turn
I believe Baer and a couple other outfits have rotors with the CORRECT construction.The problem is with the base inverted rotors.
I got the deflectors in preparation of the planed brake system overhaul, which I am now thinking throughThe problem is with the base inverted rotors. They don't cool well due to their design, and unfortunately the air deflectors won't do anything unless you get proper designed rotors which means doing the PP or GT350 upgrade.
I have wheels that will clear the GT350R brakes. When you say "6 piston Brembos do you mean to buy Brembo GT calipers as a separate purchase? .....those are really expensiveThen what is the reason you want to upgrade them (nothing on that list was the actual reason). Ask yourself what is wrong with your current brakes that you want improve ?
From your post it looks like the look - which is fine - then there is not a substantial look difference between GT and GT350 Brembos. What you also need to account for is possibly new wheels for either (especially for GT350 ones).
Given the use, you've wrote about, you will spend a whole lot of money and add some weight for something you will not benefit from during driving. Replace fronts with 6 piston Brembos, get a rotors that you like (Baers / Girodisc / Steeda) and call it a day.
6-pot/piston Brembo == PP1 brakesI have wheels that will clear the GT350R brakes. When you say "6 piston Brembos do you mean to buy Brembo GT calipers as a separate purchase? .....those are really expensive
I know it's probably stupid but what about just flipping the rotors inside out? you'll need a spacer to get the offset right but it might work.
Got you.6-pot/piston Brembo == PP1 brakes
