Aluminum valve covers.
LSchicago
Illinois
Lloyd
2018 Mustang GT/A 301A 5.0
LSchicago
LSchicago
Illinois
Lloyd
RC2017
jacksonville, Fl
Richard
2017 S550 PP1 Convertible
On similar subject, I have a '17 and just received my ford aluminum covers. Is there anything else I should think about doing at the same time?? I have thought about getting the pac springs.
SamR
Plano Tx
Sam
2020 Ford Mustang GT
Do you really have to pay $149 extra for the gaskets and seals on an $1100 set of valve covers?
No, that's a markup you can find them cheaper elsewhere or maybe even reuse. I'm doing OPG when I'm putting these on and I got all the gaskets for like 250 from ford (timing cover, both valve covers, waterpump etc...) Its still a lot but I wanted OEM.
bankyf
Fredericksburg, Virginia
2022 GT500 CFTP
I believe they are not standard valve cover gaskets and will require their specific gasket. I could be wrong though…
SamR
Plano Tx
Sam
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
Those are damn sexy covers, but a tough pill to swallow at that price. :shock:
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
I am, but trying not to spend $1,100 on something cosmetic. Those are what prompted me to look for other options.
That's for the raw cover. Another $150 required if you want them anodized. Another $149 for seals. Oh and the PCV hoses will need to be converted to -12AN fittings.
If someone is going all in on a high powered rebuild, then this would be the icing for the cake.
Tinpot
UK
2022 Mach 1 w 3rd pedal delete
Correct, they won't fit 18+ because of our direct injection pump being in the way. Same for us with the gt500 covers which I wanted for larger vents
Larger vents ?
DougS550
Fishers, Indiana
Doug
You forgot, if you Do Not want MMR logo, Yep, Another $50
Jackson1320
California
Jaxson
2015 mustang gt
if you have cams, turbos or run high rpm's then yes if not dont worries about it. are you planning to install ?
Firsttexan
2011 GT500 '19 GT PP1 '13 GT500, 98 GT, 92 LX 5.0
Terribly pricey. Especially since the previous one are blk. Once installed they will be covered with wiring and tubing.
Not much to notice in the end.
