60 foot help
PickleGT
PickleGT
Wisconsin
2017 Ford Mustang GT
My RST seems to doing just fine...I have only made 3 passes on it, but it held up well on Saturday.
glad to hear it survived a trip to the drag strip but my concern with the rst even though it’s rated overkill for my setup mcleod says it’s a street clutch and not for the strip because it’s organic and when i go racing i like to get my monies worth and get at least 10 passes in
gcadorette13
PoopStang
Missouri
gcadorette13
PoopStang
Missouri
It "should" last you more then 10 passes. I will low key cry if mine doesn't last more then a couple seasons.
gcadorette13
PoopStang
Missouri
I cut a 1.59 60' so that's a decent starting point for me.
PickleGT
PickleGT
Wisconsin
that’s pretty good i wasn’t cutting 1.58/59 until this weekend what’s your full mod list engine/suspension and weight if you don’t mind sharing
gcadorette13
PoopStang
Missouri
E85,Ported CJ, Stage 3 Comp Cams, a few BMR goodies, Viking rears, 4.09's. a bunch of other random stuff. Car weighed prob 3600 with me in it maybe a few lbs less. I think i might be at a limit of those gears unless I really push some more rpm. I trapped 122
PickleGT
PickleGT
Wisconsin
What are your ETs at 122. you still on factory front struts?
gcadorette13
PoopStang
Missouri
Yes Front is stock beside the springs, Went 11.30. 1/8 went 7.26 @96 then a 11.30 @ 122
gcadorette13
PoopStang
Missouri
dang i’ve got some figuring out to do if my cars ever going to hit 10.9999999
I got the same goal. Just keep practicing. I leave off a 2 step at like 6500-6800 and that helps a lot in the 60 for me at least. If you can't get it to make any more power then try to decrease the weight. That kinda where im at with it.
PickleGT
PickleGT
Wisconsin
yea i’ve got my wot box set to 6500 and it took like 300 DA to run my number 3700 pounds with driver
gcadorette13
PoopStang
Missouri
What gears are in the car? I would work on that weight unless you want to start looking at a CJ mani.
PickleGT
PickleGT
Wisconsin
3.31 i’m almost out of 3rd gear
PickleGT
PickleGT
Wisconsin
@JakeLethal would you recommend either the street fighter or warrior clutches for NA drag racing and still being streetable?
