3.48 Pulley - 10psi?
Jay159866
2015 GT 1966 Coupe
You said you reset your boost gauge, do you have an electronic or mechanical gauge? Maybe there's a disconnect in the amount it's reading. It sounds a bit odd to have that much fluctuation, also, do you have an intercooled set up?
I would suspect the boost gauge as well unless it is down on power.
It is an electronic gauge but I had a friend hook up a brand new, still in the box gauge to my car and it read the same as mine. I do have an intercooled setup. I'm going to go take it for a ride/datalog and come back while it's hot to do a leak test.
U need to check your engine vaccum at idle and see what it is.Warmed up it should be around 22.Also best way to check for leaks is find someone with a smoke machine.
I'm going to do another datalog, so I'll pay attention to the vacuum at idle and report back. I'll see if someone local has one. Shouldn't be too much to have it smoked, yeah?
venumous
PA
16' Procharged GT
Mechanical boost gauge is the only way I ever go with my cars. Seems like the BOV fixed the actual problem and now its the gauge?
Jay159866
2015 GT 1966 Coupe
I went out driving for 30 minutes and checked it when I got back in the driveway. The stock vacuum/boost gauge was showing 19.7 while my AEM X-Series boost gauge was showing -20.4 to -20.8 vacuum. I think the BOV fixed the issue and now it's a matter of belt slip due to the SC oil getting onto the belt.
I made 12.5 lbs on my first run after letting the car warm up for 10 minutes in the driveway. After that, I was only able to make 7.5-10.6 lbs. I popped the hood to look if the belt came off at all and noticed oil coming from the SC fill up. It's not over-filled and it has a brass washer. I'll replace it and see if it still leaks.
I think the BOV fixed it and now it's just belt slip. I'll check into a mechanical but I like the fact I can go back and see what my boost was at (X-Series)
kcc0521
Falls Church VA
Bo
2015 Black GT PP
Did you install the vent plug when you installed the supercharger?
dubster99
Nor*Cal
2015 Ingot Silver GT PP
His dynos were way low. So its not making boost for some reason. Like he said, he got oil on the belt.
Jay159866
2015 GT 1966 Coupe
I seemed to of fixed the oil leaking out issue but still only making 9-10 pounds. I'm wondering if the belt just isn't tight enough, even tho it wasn't easy to put on. 101 5/8 gates HD belt on the 4th hole from the left. Maybe I'll try out at 100 inch.:shrug:
Ponderthis
Boost Loading...
Senoia, GA.
Chase
2015 GT Premium
Just realized we have the same belt... it's in the wrong hole on the tensioner! I had the same issue, literally same result as you 550whp... moved hole tighter, 700+whp lol.. try 3rd from left hole, should be middle one!
Jay159866
2015 GT 1966 Coupe
I'll try it when I get home. Stock belt tensenior?
Ponderthis
Boost Loading...
Senoia, GA.
Chase
2015 GT Premium
yep
Ponderthis
Boost Loading...
Senoia, GA.
Chase
2015 GT Premium
Thats right, tensioner shouldn't be maxed out at least mine wasn't after it settles and runs for a minute..
Jay159866
2015 GT 1966 Coupe
I took it for a drive and it's still maxed out. I got on it a few times.. Made 10lbs, 14.3 lbs and 13.5 lbs. I pulled over, looked under the hood and there's oil all over. I ensured it was all clean before I took it for a drive. I think the leak is coming from the drain line connection, I'll look into that on a day off... But about the tensioner..
Ponderthis
Boost Loading...
Senoia, GA.
Chase
2015 GT Premium
Supercharger oil? Weird ya check the drain line..
Jay159866
2015 GT 1966 Coupe
Yeah, SC oil. It's not coming from the top, it's all over the bottom and on the bracket. I'll deal with that on Monday. I'm just wondering why my tensioner is maxed out if we have the same setup.
