3.48 pulley on pump 93?
beefcake
Bethel
2018 Ford Mustang
i think its too much boost on pump, with rpm , your gonna see 10lbs or so, which is gonna make 650-700 depending on the setup..
Jordn5.0
Kennesaw, GA
Jordan
2020 Mustang Gt Boosted MT82
Bumping this one back up. Just installed a 3.4 pully and running 93 with boostane on my Gen 3 10r80. Have you guys had any issues since?
I’m about to do the same - Alejandro video from Lund did it to test but used c16 and 3.33 pulley picked up a 7.2 sec 60-130 time with stock clutch . He said the graph was super clean and didn’t even change tunes
cbrtrx
tampa fl
2016 mustang gt
C16 is not even close to adding some boostane to 93, just saying. I have a griptech 3.47 pulley if you need one.
markmurfie
Hawaii
Mark
2015 Ford Mustang GT
Can you clearify, im not sure what you are saying is better, or easier to use, or what?
cbrtrx
tampa fl
2016 mustang gt
93 with a little boostane added will not have the same benefits as c16, so they should not be compared as the same as to what is safe. When using anything less then a 3.6 pulley the octane starts to become important.
