3.15 gear, what models have them?
Nagare
Ft Lauderdale
2017 Lightning Blue V6
Worth mentioning that shipping will run in excess of $100 most likely. It is just heavy enough that your local Fedex won't take it (mine was drained and over by about 5lbs I think it was) and doesn't fit the traditional boxes either so they'll have to make a custom heavy duty box for you.
Mine was from FL to PA and ran $175 including packaging!
onefastmf
Orland park IL
james
2018 Lightning Blue
So i found one! I'm going to pick it up wednesday, he is gonna see if he can find anymore and i can pass it on to anyone looking to get one. Thanks to everyone who helped
DANA44
Central Connecticut
2016 v6 convertible
Keep in mind that there 2 different pinion flanges styles for the 15-17 MY. One for the auto and the other for the 6M as the drive shafts are different . It is my understanding sometime with the MY 18 a change was made to the drive shaft design as a result add 2 new pinion flanges to the mix. Attached file is a Ford how to swap from a manual to Auto with 1st gen drive shafts.
onefastmf
Orland park IL
james
2018 Lightning Blue
I would love for some who has done this to chime in, but from my understanding i can swap my flange, or I'm i crazy? or just dumb,lol
dh3605
Nashville Tn
2019 GT, 301a, Auto, Black, Black accent package
I have a 2019 A10 with 3:15. Would like to go to 3:55 . Exactly what is needed to swap out.
onefastmf
Orland park IL
james
2018 Lightning Blue
That depends on what your trying to do? Do you care if it’s a iron housing? If you want a iron housing for more strength than you will need a rear out of a manual car and have to swap the flange to a automatic type, if your not after strength then you can find a aluminum housing from a a10 auto w/3:55’s and it would be a straight swap.
Zathras
So the A10 cars (non-PP) have the aluminum housing even if they have optional 3.55s?
onefastmf
Orland park IL
james
2018 Lightning Blue
I think All A10 cars have aluminum housing, mine is a non with 3.55 and it’s aluminum, I believe the same is for the a6, only cars that have iron are manual cars, I believe
For the 2018/19:
Depending on if you are buying new or used, the Performance Pack equipped Mustangs all now have a Torsen rear.
GT MT82 w/ Torsen has 3.73’s.
GT or EB 10R80 w/ Torsen has 3.55’s.
The cases are iron regardless if the trans is a 10R80 or the MT82. Again, be aware of the auto vs. manual trans rear diff pinion flanges. Another thing to be aware of with 2018/19 rear diffs, if it matters to you - the 2018/19 PP rear diff cover is predrilled for the rear axle temp sensor. I’m not sure if the diff cover on a 2018/19 w/3.15’s even has the sensor.
A 2018-2019 EB or GT PP iron pumpkin is coated black, with all gray cast aluminum rear cover.
TIP:
- If the rear diff has Trac-loc guts, you won't be able to see through it with axles removed. There will be a "bar" in the hole which is for the spider gears.
- If the rear diff has Torsen guts, you'll be able to see through it with axles removed.
2015Etrac
PA
Black 2016 Mustang GT Premium 401a
Not sure about the 10 speed, but when I was looking into adding a 3:55 differential to my 6R80, there was some debate over what was needed to change the auto shift points. Some people said a tuner could do it, others said FORScan was needed, and even a few people said nothing was needed, but I never found a definite answer. I would like to get one of the new performance pack 3:55 torsen diffs.
olaosunt
Indiana
I got one .
I swapped the one in my 18 PP /GT auto for a 3.31 out of manual .
I also a have an aluminum one out of my 2015 /auto
I want a 3.15 iron one if I can get one
Not willing to ship though. I tried before and it never got delivered after all the work I put in to packing it .
