2020 GT350 - Oil-Air Separator
EDL
southeast, US
GT350
searched without success
did the 2020 come stock with either the side (or both) oil-air separators installed? or are those strictly aftermarket?
Thx!
NightmareMoon
2016 Mustang GT PP w/ Voodoo
I don’t think they came with them, but Ford Performance does make good quality selerators for both sides if you want them.
galaxy
St Louis
'17 GT350
None ever came installed new/from factory. Austin is right, the FP one's are nice and fit to look like a factory install. Also tons of aftermarket options if you so choose. Driver side not needed unless you're tracking the snot out of it, and even then, I've seen reports it catches minimal oil on rare occasion.
EDL
southeast, US
GT350
Thanks PB ... thinking just the GT350 here....but good to know
526 HRSE
California
2017 GT350 Grabber Blue
None for the gt350 and i believe the 500 one is a bit different. Regardless, you'll only need the passenger side for the 350
72&18
Charlotte
Doug
72 Mach 1, 18 GT350, 22 Bronco 2 Door
You only need a passenger side one. My driver side has never had any oil in it.
EDL
southeast, US
GT350
Just installed passenger side -- on the longer tube, videos say 45deg goes on separator 90 deg on engine...found (for a 2020) that the opposite fit up more naturally - do others have the 90 deg on the engine or the separator?
Postal Bob
Long Island, NY
Bob
2019 Shelby GT350
I remember I either reversed/switched the tubes, or reversed the direction of one. Again, as you said, because it fit better.
These seperators are made to go in several different cars, with different engines, which is why it's not always an exact fit when installed. And I found if you warmed the tubes with a hair dryer, it makes bending the tubes easier without kinking them.
guzie
Grand Rapids MI
2018 Mustang GT350, 2019 Mustang GT
I have seen a bit of oil in the driver one I had on my first gt350 after a day at the track where I really pushed it. I’m putting both sides on my latest GT350 to cover the track days
