2020 GT full Hellion build
Flubuyu2!
Amarillo
Mark
2020 Ford Mustang GT, C7 Z06 Corvette, Audi B9 RS5, BMW X4 M Comp, SLK55 AMG
Hi There,
Posting here as well as the new member thread as I am sure to be here often. Here is the list and some photos:
ALL MODIFICATIONS PERFORMED BY GEARHEADS PERFORMANCE
750WHP @ 10PSI ON 93 OCTANE
FULLY FORGED 5.0 ENGINE
MAHLE FORGED PISTONS
MAHLE STAINLESS STEEL PISTON RINGS
FORGED H-BEAM CONNECTING RODS
ARP-2000 ROD BOLTS
FORD PERFORMANCE MAIN STUD KIT
ARP HEAD STUD KIT
MMR BILLET OIL PUMP GEARS & CRANKSHAFT SPROCKET
HELLION "SLEEPER" TWIN TURBO SYSTEM
UPGRADED 62mm BALL-BEARING TURBOCHARGERS
HELLION LARGE FRONT MOUNT INCERCOOLER
TWIN TURBOSMART COMP-GATE 40mm WASTEGATES
TWIN TURBOSMART VEE PORT BLOW OFF VALVES
AEM TRUEBOOST BOOST CONTROLLER
GEARHEADS PERFORMANCE DUAL OIL CATCH CAN KIT
IMRC LOCKOUT KIT
UPGRADED NGK SPARK PLUGS
FREE FLOWING MID-PIPE TO OEM ACTIVE VALVE CATBACK
MCLEOD RXT TWIN DISC PERFORMANCE CLUTCH & FLYWHEEL
FULL SHELBY GT500 FRONT BUMPER CONVERSION INCLUDING ALL LIPS, CANARDS, LIGHTS, ETC.
GT500 STYLE VENTED HOOD
GT500 STYLE FAKE HOOD PINS
CUSTOM RED COYOTE GRILLE BADGE
MMD V-SERIES COLOR MATCHED REAR SPOILER
NGOT8R
Adrian
2019 Bullitt
Nice mod list! Sounds like it should be pretty stout and reliable. Did you utilize the coolant ports on your wastegates to keep them cool and help them live a longer/happier life? Any pics of the turbos and intercooler mounted? Curious to see what Gearheads did for the front bumper support.
Are you still on the factory MT82-D4, but with the upgraded clutch and flywheel? Roll racer, road course or drag car (or all the above)?
Flubuyu2!
Flubuyu2!
Amarillo
Mark
As far as I know the 6 speed is stock. I will look for the ports when I get home and take some pics of the turbo's hanging under the car and front end work. We are road racers out this way.
NGOT8R
Adrian
2019 Bullitt
Oh okay. Here’s a pic of one of my wastegates to show the coolant symbol that you’ll be looking for. There will be one on each side of the wastegates and either side can be used as feed/return. See also the Turbosmart coolant hose connection diagram pic below. FatHouse Performance also makes a coolant distribution block to facilitate using the cooling feature on these wastegates. See link to FatHouse below as well.
https://www.fathouseperformance.com/product/coolant-distribution-block-orb/
Flubuyu2!
Flubuyu2!
Amarillo
Mark
Thank you for this! I will check and see if there are lines already plumbed.
NGOT8R
Adrian
2019 Bullitt
You’re welcome. It would seem that you’d stand to really benefit from utilizing this feature on a road race car.
Zrussian13
Phoenix
Do the gen 5 compgates have coolant lines? I've got the gen4s and they do not. I've also got over 50k miles on them and 3 arizona summers so I'm guessing it's not that necessary.
NGOT8R
Adrian
2019 Bullitt
Yes they do. It’s definitely more work to plumb them for use of the coolant feature, but Iā€˜m planning on using mine. I just ordered one of these FatHouse coolant distribution manifolds to help make things a bit easier. It’s my understanding that turbos generate a crap ton of heat, so I want to do everything that I can to mitigate the heat.
Then there’s the need for a good cooling fan setup, which is a whole other story.
RMoeslein
Pittsburgh
Rich
2022 Mustang Mach 1, 2020 f250 lariat Tremor
Hi There,
ARP-2000 ROD BOLTS
ARP HEAD STUD KIT
IMRC LOCKOUT KIT
Sick ride!
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Slick piece but will be a pain to get to the top 2 bell housing bolts with that manifold in place.
NGOT8R
Adrian
2019 Bullitt
I agree! I will run a Holley low-ram IM this time around, plus without any IMRC components in the way, I will create a little extra room. I don’t expect it to be a piece of cake though (of course nothing ever is). I may also explore different options for mounting it which will require a bracket of some sort to be fabbed up. I’ll share more info. about the port sizes and flow path once I get it in hand.
Zrussian13
Phoenix
I'm just not seeing the need for cooling to the wastegates??? I beat on this F'er until it gets over 105° out here and never had an issue. What does cooling the wastegates accomplish? I get the extra water cooling to the turbo but I don't even do that out here. 104,xxx with oil cooling only since 48k and turbos and wastegates are solid. Am I missing something?
NGOT8R
Adrian
2019 Bullitt
Many people get by without cooling the wastegates, but Iā€˜ve read about people having issues with their cars running hot with the supplied fan, so I want to use every feature available to help everything live longer. Wastegates aren’t exactly cheap at $400 each.
I will also be running a Delta PAG single 14ā€ fan that’s capable of pulling in 2600 CFM to help keep things happy. I’m learning as I go here and I haven’t even started work on the car yet, lol. When the time comes to begin work, I want to ensure that I have every possible scenario covered.
Zrussian13
Phoenix
I will also be running a Delta PAG single 14ā€ fan that’s capable of pulling in 2600 CFM to help keep things happy. I’m leaning as I go here and I haven’t even started work on the car yet, lol. When the time comes to begin work, I want to ensure that I have every possible scenario covered.
Totally get trying to keep everything cool but I'm struggling to see how coolant lines to the wastegates will keep anything cool? Other than maybe the diaphragm inside it? Seems like senseless extra lines to run so I'm just trying to wrap my head around it. Clearly turbosmart added them for a reason but I don't see it....
NGOT8R
Adrian
2019 Bullitt
Take a look here at this link to a thread at Garrett Turbos. Read the test data near the bottom of the page. There’s a huge difference in the temperatures between non-cooled and water-cooled.
https://www.garrettmotion.com/knowl...nce/watercooling-your-gvw-external-wastegate/
