Base Hellion Sleeper Kit Results 2020 Mustang GT
MidnightGT
AR
2015 GT
Well, finally got my car on the Dyno today to see what power it’s making.
2020 Mustang GT
Hellion Sleeper Kit w/ base 62/66 ‘s
Fore L1E w/ dual Walboro 465’s
1050x
Billet OPG’s
824/756 @ 12.9# on e85
Peak hp was made @ 6450 rpm.... and was expecting power to climb to redline.
Any thoughts on this?
Nevertheless I’m happy with the numbers.
MidnightGT
AR
2015 GT
Nice solid #’s. Just curious, but what was the total cost on your setup?
PBD Level 1 Hellion Package w/ NGauge and Eboost Street ~$8,600
Fore L1E w/ basically all the upgrades (FC3 controller, Honeywell switch, boost/vacuum block, upgraded to high pressure Walboro 465’s, stainless filter, etc) and ID 1050X ~ $3,000
opg/cs package ~$400
All-in-all around $12k and I’m sure it could be packaged together for a little cheaper. I didn’t decide to go e85 until after I ordered the Hellion kit. So it was pieced together after the fact.
IrishStallion
Missouri
18 gt mustang
Nice!
Did you install it all yourself or have shop do it?
MidnightGT
AR
2015 GT
Nice!
had a shop do it as I got a “buddy” deal of the century. $2,000 for all of it to be done - Opg, turbo kit, fuel system
wazslow
PA
2016 Mustang GT/CS
Whats the exhaust setup? Did you option the boost actuated cutouts?
MKL_DS
Central Forida
2020 GT PP1
Looks like similar issues another TT car had where the exhaust restrictions start leading to valve float.
15GTPP
El Paso
2019 GT
Nice numbers! I actually paid the exact same for installation on the kit, fuel system, and opg/cs. The best thing is I was able to be there for it and learned a lot. Here’s my dyno sheet for comparison. Only difference is I’m running the Precision Gen 2 BB 6266’s and a Corsa Sport Catback. This kit is very impressive.
Runs were done on 9, 11.5, and 15 psi on pump e85.
Jackson1320
California
Jaxson
2015 mustang gt
2020 Mustang GT
1050x
Billet OPG’s
Your numbers should be higher and rise a lot farther if not all the way to redline. Can you data log boost? You might not be holding steady boost all the way to redline
MKL_DS
Central Forida
2020 GT PP1
That’s a very low boost to be causing valve float
This is the 2nd one of these kits to post recently with good power numbers that happened about 1000 rpm too early. Makes me wonder if there's an exhaust issue.
MidnightGT
AR
2015 GT
I did not get boost actuated cutouts, and this was a concern of mine. It’s 3” back through MBRP mufflers.
MidnightGT
AR
2015 GT
This is how I anticipated my Dyno graph looking. I’ll send my data log from the run and Dyno graph to my tuner and see if he can see any correlation with drop in power.
