2018 P2119 Code on Whipple
JRavelo
Jesus
2018 Mustang GT Kona Blue, PP1, Whipple Stage 2, 3.625 pulley, ID 1050x, Fore triple, E85, ARH 1 7/8", Corsa Extreme, A10R80 upgraded clutches, Full Steeda suspension, PBD tuned, 820 RWHP/615 RWTQ
replace the gasket with the rtv, I’m sure the ultra is fine
Thank you sir. Did this "fix" resolve the issue for you?
TX-Ripper
SE Texas
2019 Mustang GT PP1 Whipple Stage 2 / 2018 F150 5.0 Whipple Stage 2
Yes and Sort of, the real fix is the tuning company adjusting the amount of time the throttle blade can hang before it sets this failure code.
JRavelo
Jesus
interesting... did you ultimately have PBD adjust the tune? if so, does that pose any potential issue?
18 Smoke
Columbus, OH
18 Mustang GT PP1 400a
Try the RTV. Rob made a couple of adjustments for me, but I continued to have problems until I did the RTV. Haven’t had a problem since
JRavelo
Jesus
Thank you sir!
TX-Ripper
SE Texas
The tuning software may not have the tables they need - hptuners or sct
whipple says future calibrations will have it but Whipple uses oem ford software
JRavelo
Jesus
Lat night I went through with the disassembly process and visually inspected the throttle body and how it sits against the SC and it's relationship to the existing gasket.... then I start to think... conceptually, how does using the RTV vs the supplied gasket affect the throttle body sensory to create the error code? Does anyone have an intelligent response to what the theory is behind the swap? Just asking before I complete the task. I went ahead and tried to and successfully replicated the error code in normal mode allowing the transmission to perform shifting but if I place the shifter in "S" and perform the shifting myself, it will not reproduce the error. Just not understanding the mechanical concept of how the gasket is the cause and which is what prompts the question. Thanks all.
TX-Ripper
SE Texas
Distorting the body, causing the throttle blade or shaft to bind in the bore of the body.
What I was told
18 Smoke
Columbus, OH
Don’t question the logic, just do it! I couldn’t understand how it was going to help either, but sure as Hell, it fixed it for me and quite a few others that I know of
JRavelo
Jesus
LMAO... really? I am a Marine as well as an attorney... all I do is question shit!
18 Smoke
Columbus, OH
I think you’ll be pleasantly surprised, even if you’re left scratching your head, like me!
Thank you for your service, Sir!
JRavelo
Jesus
Thank you sir! it was always my pleasure and honor to serve. You are correct my friend, if it resolves the issue... damn the logic of it!
Alex.Envy
Portland Oregon
Alex
2019 GT350
Same issue just occurred for me. Reading up on this thread and just sent some logs/questions to Lund. Just got my RXT installed for my T56 and this code pops whenever I do a WOT 2->3. We'll see what they say to me in the morning. Thanks for the advice in this thread.
TX-Ripper
SE Texas
go ahead and pull the throttle body and use hi temp rtv instead of the gasket, torque it very evenly.
Alex.Envy
Portland Oregon
Alex
2019 GT350
Gonna do it tonight and see what happens. This time I'll make sure to log it.
Happened two times already and its always on the 2->3 shift. I was just wondering why it would happen after a clutch change, coincidence or maybe the fact the RXT can actually grab the power instead of slipping lol.
