Bluelightning
Bluelightning
- May 22, 2018
- North of Houston, TX
- Lightning Blue 2017 GT350, 2019 F-150 4x4 Ecoboost (Daily)
- Vehicle Showcase
- 1
Read what you just said.... If you scoped your cylinders you would have seen this coolant sitting on top of one of your pistons.... If you didn't see that then you don't have an issue.There is still pressure in the coolant when the engine is off. I shut the engine off and then opened the reservoir and you hear the pressure hiss out so it is possible that once I shut the engine off the residual pressure forces small amounts of coolant into the combustion chamber and then when I start it up the coolant gets burned up and sent through the exhaust.
