db252
Equinsu Ocha
- Jan 1, 2016
- Bay Area, CA
- 16 GT Premium/PP/Nav
1. Digital oil pressure will not work if you donât have an oil pressure gauge now. People are working on adding the correct sensor and wiring now to get it to work. Differential temp will work since you have a 16 as long as the temp sensor is in the differential; canât remember if it came with all 16âs. If you donât have it then it wonât work as well.Thinking of doing this later this year, but wanted to go through the numbers to make sure I understood any tradeoffs.
1. Some gauges like the oil pressure gauge does not work on non-PP cars. This is shown gray'd out in the option.
2. You need to send your analog cluster back into the dealer you buy the digital cluster from or take a $$ hit
3. All other functions should work including the option to set the mode the car starts in. EG, with the digital gauge even on a 2015-2017 Mustang you could make sports + drive mode the default with the steering mode also set into sport and the cluster defaulting into track mode
4. Does the startup pony animation change to the Shelby or GT animation if you've previously modified the main console splash using Forscan?
Is that accurate? Am I missing any other downsides? Tried to read over most of the thread but there's a lot of context to absorb.![]()
2. There is no reason to send your original cluster in. It doesnât count for core so forget that one now.
3. Car starts in normal mode all the time. You can lock any of the three screen settings to start up and stay regardless of what mode setting. You can create âmy modeâ setting to have what steering and drive mode youâd like to have.
4. Your Sync screen wonât change at all for whatever you programmed it with.
Iâm not sure youâll find one person in this entire post that wish they didnât do this mod. Itâs not cheap but endlessly satisfying.
