Can I adjust the 2018 digital cluster top speed
Jsolman
UK
Jason
Mustang 2018 GT (UK) A10
Just wondering if it is possible to amend the top speed on the 2018+ digital cluster?
When driving in Europe, I managed to max it out on the dial at 160 and also on the digital speed display.
So wondering if there is a way to increase the top speed shown and used.
I have seen some posts in the past on the Bullet digital dash going to 180 and GT500 to 220, but unsure if anyone has fathomed out how to amend via codes (ForeScan) etc, since then, as these would be costly options.
Jaymar
Portland, OR
Jaymar
2022 GT/CS - Rapid Red
From what I understand, they are different clusters with different software loaded. The speed and RPM are less numbers entered into a box and more a preloaded graphic that is displayed if that makes sense.
Jsolman
Jsolman
UK
Jason
Is there a way to edit or adjust the software.
I get the gauge stops with the graphic, but not sure why the digital speed display also has to stop.
No, it need reprogramming
does anybody offer this service, on an exchange basis?
Ferrcad
Western PA
Brian
2015 Mustang GT Convertible
Reach out to@breeves002, you will need to send the speedo to anyone for the program bin file to be uploaded and changed. Bullet speedo programming is what your looking for...
I Bleed Ford Blue
North East OHIO
With the OP being in the UK, sending his cluster to someone here in the US may not feasible. He needs to reach out to breeves002 and work with a shop over in the UK and have breeves talk them thru what needs to be done. Then he gets his cluster back in a day or two, sending it here he may be without it for several months if it doesn't get confiscated by customs.
Ferrcad
Western PA
Brian
Totally understand the situation but would be shocked if there is anyone in the UK doing such programming!
I Bleed Ford Blue
North East OHIO
Get ahold of Mike Brewer of wheeler dealers fame, he's back in the UK and I've seen a few episodes were he had gauges and clusters repaired and modified, he might be able to steer you in the right direction.
