2018 Digital Cluster Installation Guide
breeves002
breeves002
Gold Sponsor
St. Louis, MO
Sam
2016 GT Premium PP
cryogenicdreamz
Casey
2021 mustang GT
I have a 2021 auto car i did the swap the donor car was a 21 as well swap went smooth only thing is the right lower buttons aren't working the pony and setting switches wont work when clicked what lines do I have to edit in forscan?
rothrj91
Michigan, USA
Grabber Lime PP1 GT
The above spreadsheet has a sample IPC and SCCM ABD you can use as a baseline for your modules.
Note: Some clusters have newer software that FORScan may not support in the latest release. If this is the case PM me for a beta build or email the forscan team for a beta build.
You must select your features and adjust the as built data as necessary. Any lines that do not have a feature set use the supplied as built data at the bottom of the page.
You must also adjust the as built data in the SCCM. You can use your old SCCM as built data except for line 724-03-01. Should be set to 1733 xxxx xx without adaptive cruise or 2933 xxxx xx with adaptive cruise.
To avoid a U2100 code in both the SCCM and IPC I recommend changing ALL ABD and then hitting "write all" at the bottom. If you are testing things, start with the baseline ABD and write all then change things one at a time. If you have the U2100 code and need to get rid of it, save your as built, change some as-built in 4+ lines, write all, then load the saved as built and write all again. Clear codes and read codes. Hopefully its gone! If you have other codes that come back after you clear codes there may be a problem with your as built data.
I believe SCCM module line 724-03-01
JDuncan
Georgetown, IN
James
2016 Mustang GT Premium PP / 2018 Mustang EB Premium Convertible
but I've got a problem: the RPMs aren't working. Everything else is fine except the RPMs. Any idea what could be causing this? Did I forget to change something in the IPC settings?
720-07-0200000030CRITICAL FOR RPM
stangnyc
NYC
jon
2020 Ford Mustang GT
I just finished upgrading my sync 4-8 and to the digital dash. My Pony button, cruise control, Exhaust mode, phone answer/decline, radio sound is weak and settings on the dash aren’t working. Is this a programming issue or will i not be able to obtain this. Please let me know if you have an info on this.
svtcarter
carter
99 Cobra, 2019 Gt
Are you able to decrease miles with forscan? I wanna do the swap but having a hard time finding some with less than 18k miles and dont really wanna cough up $2000 when I could find a used one for half the cost
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
No you cannot….you can only increase them with FORscan.
kubko
Slovakia
Ford Mustang Ecoboost 2017
Does anyone know by chance if it is difficult to disassemble lens cover from the display? There are some dust particles trapped inside.
Ferrcad
Western PA
Brian
2015 Mustang GT Convertible
Nope, I replaced mine since it came out of a wrecked vehicle and had a scratch. Four plastic clips and came right off the display. Then put the new one on. Ford part number JR3Z-10890-JA new around 15 bucks. Pull the part up and you will see the tabs. GL
Whitedevil95
Temecula, CA
J.P.
2022 Mach 1 HP
Yep super easy pops right off.
BlownGP
Houston/Baton Rouge
Steven
Pontiac, Ford, Dodge
Yup, did the same to mine.
