2018 Digital Cluster Installation Guide
Ferrcad
Western PA
Brian
2015 Mustang GT Convertible
So you can't just order the cluster online from a Ford parts dealer? I just need the cluster now, not the whole kit. I managed to find all the other parts pretty cheap. I just wanted a new cluster from Ford. Can you not do that?
You should be able to order the part directly from Ford, did you check the first part of the this thread for details? There is a guy in MI, Autonation Ford White Bear Lake that you can contact directly to order the parts needed. You will be on the hook for the core charge. No way around if your ordering new. I purchased my steering wheel switches and dash cluster cover from him for a little over $100.
ctandc72
VA
'19 GT 6 speed Base
Well I guess the chip shortage is hitting here too....went to order the Bullitt cluster today from a friend at Ford...national back order. Figures.
Domstrebe
Germany
Alex
Mustang GT MY2018 PP1
I have a 2018 GT Premium. Is it possible to add a cluster from a 2019 or 2020 or do i have to go with the 2018 one? Are there any differences?
The main reason why I'm asking is that the 2020 one is a good 200$ cheaper than the 2018.
bladeblade
Brno
Lukas
Mustang GT 2016
hello I'm loading you EEPROM it's in km Bullitt max 300km/h and GT500 max 360km/h
PWn3R
Flagstaff, Arizona
Allen
2016 Shelby GT350, 2013 Ford Raptor, 2014 Ford Escape
This guide is a masterpiece. I have a 2016 Shelby GT350 and after reading about 50 pages, I haven't seen anyone saying things are in a better state than what is in the FAQ at the beginning for GT350s. I am very interested in this, but I also don't want "partially working". Has anyone been able to get this fully functioning on a GT350?
BoostKing
Brett
18 S550 5.0, 22 F150 Tremor, 22 Expedition Stealth
I know the MACH 1 just came out, but it looks like it has an auto 180 mph cluster. Does anyone know the part number? I cant find it on any Ford parts sites yet. Thanks!
HoosierDaddy
Randy
Get the Canadian cluster; 290 looks even more impressive to passengers.
puelloj
Jose
2019 Mustang GT Base Auto
There shouldn't be much of a difference between the years. I believe the firmware is the same. Just make sure to order the correct speed(mph vs kph) and I think ideally the trans type(auto vs maunal).
codereddew
2019 Mustang GT PP1
looking to sell my digital cluster - if buyer has same year car/trans and basically same mileage, do they need to reprogram it for their VIN or can they just plug/play?
NC GTier
North Carolina
Haider
2018 Mustang 5.0 Conv Auto Silver
They need to tweak the as built setting via forscan, to accommodate the digital dash and disable some systems like pre collision, blind spot, front cam, etc. So they wouldn't show on dash as non responsive systems. Assuming buyer doesn't have these systems but donor car has.
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
Mileage can only be set to a higher number by the new owner. So you need to disclose your odometer reading.
Ferrcad
Western PA
Brian
Stangtime, not totally true, if your able to find someone with the dash firmware and flash tool it can be adjusted to zero and then use Forscan to adjust up to current mileage. I believe the thread owner is able and along with some others. Some can even change it to a 180 MPH speedo (Bullitt), automatic to manual or vice versa. Some charge a fee for the service.
Ferrcad
Western PA
Brian
wheres the best place to order the switches and bezel last parts i need
I got my switches from here... but check around with Google for best price.
AutoNation Ford White Bear Lake
thecloneranger
houston texas
2018 royal crimson mustang gt
thanks for the forscan i have a base 2018 mustang any one have a sheet i can use as a guide for forscan
