2016 Mustang GT PP1 starting issues
Crete
Houston
Logan
2016 Mustang GT PP
Howdy,
I have a 2016 mustang that has a strange starting problem. Most times it starts right up no problem but every couple of start ups, it will crank without starting. Now I’ve realized that it doesn’t start if the i don’t hear the initial whine (which I think is the fuel pump) when you go to start the car. When it doesn’t start on the first try I have to shut off the car, Open the door, close it, click the car into run and then the whine is back and car starts fine.
Any ideas would be greatly appreciated!
kluke15
Reno, NV
Kenny
2017 Mustang GTPP
Howdy,
if manual it may be clutch switch on the back of the clutch pedal. if auto i have no idea. my clutch switch started going out. most of the time would start up just fine. other times it would crank and never fire. replaced clutch switch and starts up everytime first time.
NoVaGT
Northern Virginia
2019 PP1 GT Kona
Replace your battery.
Mustang gt 2016
Oman
Alex
Mustang gt manual 2016
Same happened to me and i replaced the clutch pedal switch sensor. Google it and found that ford really did recalls for some particular cars and replaced it for them. Its so easy to replace it yourself. Cheap and easy to replace.
Mustang gt 2016
Oman
Alex
If there is no message stating “ press the clutch to start “ then It might be battery issues or something went wrong.
Crete
Crete
Houston
Logan
2016 Mustang GT PP
Crete
Crete
Houston
Logan
2016 Mustang GT PP
I will definitely try this.
