How to get DTC’s from dash cluster using Engineering Test Mode
For those that don’t know and may be having intermittent drivability issues - but don’t have their own external hand held scan tool, you can extract stored DTC’s from the main dash cluster.
I had posted this a while back in another thread, hopefully it has an added benefit for the DIYers.
If you have a 2015-2020 with the ANALOG gauge cluster, you should be able to enter the “Engineer Test Mode” and will be able to see stored DTC’s.
Follow this link:
https://www.mustang6g.com/forums/threads/engineering-test-mode.27581/
If you you have a 2018-2020 with the DIGITAL cluster, you should be able to access the same test mode found here:
https://www.mustang6g.com/forums/th...n-18-digital-dash-old-way-doesnt-work.115231/
Elp_jc
None
First of all, what did he mean by getting the dash blank? The dash is never blank unless off :). Did he mean having the navigation mode under (the 2-gear) settings where the middle lower part is blank (assuming you have navigation off)??? The devil is in the details. Ha ha.
And for you: Is it intuitive where to find the DTCs? If not, please post details too :). Thx.
Finally, is there a list of all the things you can change (or check) under that engineering mode? It'd be great. Thanks again.
Jaay_d5.0
California
Daniel
2019 Ford Mustang Gt
Follow this link:
Still no dtcs sadly
