Thank you! Less timing on the f1a94 pull.Thatās awesome. Was timing relatively the same between the two runs?
Im using stock 2016 phasers, no additional limiters.Thing is awesome. I didn't notice, cams are still active (not locked), correct? Did you put phaser limiters in?
Impressive.Im using stock 2016 phasers, no additional limiters.
Why do you say that?Impressive.
Well, I have no personal experience, just a noob doing research on my upcoming build, but those power numbers with stock/unlocked phasers with aftermarket cams and valve springs seems rare. I could be wrong.Why do you say that?
I have heard of some folks having issues, but who knows what the root cause is? Could be lots of things, not just the notion that oem phasers wont work at higher power levels. Many people run different oil pans, pump gears, swap heads without looking at oil restrictors etc. Im not a tuner but id assume there is a tuning element there as well. Im fairly certain that the folks having issues is rare, in comparison to those that dont.Well, I have no personal experience, just a noob doing research on my upcoming build, but those power numbers with stock/unlocked phasers with aftermarket cams and valve springs seems rare. I could be wrong.
Either way, still an impressive build
Cmon warmer weather!!The car is just amazing! Cant wait to see some track pulls with the new blower.
What's this cold weather you and @turnswrench talk about? Isn't 39 degrees cold . You guys need to move west . But then again you might melt in summer .Cmon warmer weather!!
Under 50 is cold to me!What's this cold weather you and @turnswrench talk about? Isn't 39 degrees cold . You guys need to move west . But then again you might melt in summer .
I think your in the area then .Under 50 is cold to me!
I never saw any data that supported it being effective.Been stacking up my parts for my build. Saw that through your build you didnāt use any head cooling mod that are available.
Any thoughts on that mod?
Sounds good to me. Iāll just put the injectors that flowed a little on the high side from my injector data in those back cylindersI never saw any data that supported it being effective.
