0-60 Times
Bullitt0819
Bullitt0819
Modesto, CA
Bob
2019 Bullitt Mustang
Ive got an 18 GT PP1 and I eeked out a 4.8 yesterday. I've only been driving stick since September so its not pretty, but slipping the clutch from 2500RPM and pinning it after she rolls forward was working best for me.
I think if it was warmer here I could get 4.7 maybe 4.6 If I really beat on it. It was only 55 degrees here yesterday on my way home.
Actually, cooler air = more power--for a naturally aspirated engine--for a given atmospheric pressure. Yes, cooler air is denser, but any increased drag is probably immeasurable. This gets driven into pilots as 'density altitude;' e.g. on a warmer than standard (59degF) day an airplane at sea level will perform like it was at a higher altitude: less engine power, less lift, less thrust from the prop (or turbine), longer runway required for takeoff, less climb rate to clear obstacles, etc. Yeah, a baseball will travel farther on a warm day but, the loss of power from less dense air is of more consequence to an airplane (or car).
YoloBathsalts
Chicago
2018 GT - PP1
Yes, colder air = more dense air = more power. I'm more or less talking about having a better 0-60 with properly heated tires (not trying to use line lock beforehand). These P-zeros take to heat really well until a point and then they lose all grip when overheated. Think i'm gonna get Nitto Invos next with those RTR Tech 7 wheels. they look killer. You were a pilot IIRC right? mentioned in another thread.
NoVaGT
Northern Virginia
2019 PP1 GT Kona
To get the best 0-60 times, you'd have to rev to 3-4k RPM, dump the clutch and pin the throttle. That's a bit hard on things, mechanically, so I haven't done it.
Might do it some day if I can find an empty piece of private pavement to try it on. The local constabulary are a bit ornery.
Bullitt0819
Bullitt0819
Modesto, CA
Bob
Yeah. 'Dormant' pilot (Commercial Single-Engine Land with Instrument Rating); I entertain thoughts of getting back in the cockpit someday. Family matters supersede that desire, for now.
Good point about the tires. I just want to get under 5s--at 5.2 now--just to say I did it.
YoloBathsalts
Chicago
2018 GT - PP1
Id suggest a lower RPM and more slip to get it going, then when shes moved about ten feet just pin it down. I've had better results doing that, higher RPM i just spin like crazy.
Fatguy
Toronto
2017 V6 Mustang
Just keep improving guys. It’s not all about numbers!
DesertRat5115
Phoenix
2019 GT Velocity Blue Stock + 275/40R18-9.5 Square
Has anyone tried a 0-60 run with stock 18" 235's just to find out how much slower it is?
NoVaGT
Northern Virginia
2019 PP1 GT Kona
Sivi70980
Lacey, Washington
Mark
2019 Ruby Red GT PP1 M6
99% stock 2019 GT PP1 manual transmission. So far best is 4.8 but I know I can do better. LC works by design (I hope!) but makes me feel like something's gonna break. I also feel like I can do better slipping the clutch a little.
NoVaGT
Northern Virginia
2019 PP1 GT Kona
onlyturbo
Long Island NY
Rony
2015 Mustang GT PP M6spd, 2016 Audi S4 (Sold)., 2009 Subaru STI (Sold), 2003 SAAB Aero (Sold)
NoVaGT
Northern Virginia
2019 PP1 GT Kona
Bolt on no prep country rd
I mean, technically a Hellion kit is "bolt-on", so you gotta give me more details than that. That's half a second faster than the factory spec, and that is probably made on a prepped track. Also, country roads, take me home, to the place I belong...
Yes. Details on your mods. Please.
bigwill90
Roberta, GA
Will
Lol honestly this was done on a back road no prep ..
Lund tune
17”Drag pack Mickey Thompson R radials
BMR rear suspension 3.73 gear
Circle D N/A converter
I believe it can get it lower around 3.2 to 3.3
