Leaked: 2019 GT500 5.2L Supercharged Engine Wiring CAD Diagram from Ford!
zackmd1
Zack
So I saw this awhile ago when I first looked at 2018 wiring diagram info but just assumed that it was a different intake manifold for the 5.2 GT350 as these appear when looking at 5.2 diagrams for the 2018. Now that I look at it closer though I can see the supercharger underneath!
As stated, these images appear in the official 2018 wiring diagrams available from Ford.
*Also as a note... Do not look to much into the wiring information seen in the image as it appears that the wiring file is from a GT350 as you can see it go through the supercharger intercooler in a few places and the throttle position sensor connector is just floating in space.
MikeyV
Bay Area, CA
2014 GT Premium - Brembo - Race Red
Wow. Looks like you can even see the Cobra embossed on the SC case in the second image.
Nice.
Stage_3
MA
2019 Roush Stage 3
Wow,.....nice catch Zack.
I think you're onto something there! :thumbsup:
stanglife
Jeff
1993 Coyote Coupe
Damn, that's a find right there!
stanglife
Jeff
1993 Coyote Coupe
Also seems very DI, to me!
Also a little cool that his post is #2018... I'm a nerd.
zackmd1
zackmd1
Zack
Not sure the DI system found on the 18 5.0 will fit under there... I also do not see any previsions for the High Pressure Fuel Pump on the passenger side cylinder head so I would not hold my breath for that.
zackmd1
zackmd1
Zack
Somebody at Ford that creates these diagrams F****d up.
stanglife
Jeff
1993 Coyote Coupe
Interesting either way. If it's not DI - that just means it will be an easier upgrade for GT350 owners ;)
Rich
Roseville, CA
2015 Mustang V6, Suzuki C50, former 67 Mustang owner
Ford is typically tight lipped about everything. I wonder if this is an intentional leak to draw interest?
likeaboss
Baltimore, MD
2020 Corvette Z51
The leaks keep on coming!
Epiphany
Global
I like to disassemble things.
Service CD for 2018 Mustang isn't even available yet from Helm.
You work at a dealership Zack?
thePill
Camaro5's Most Wanted
Pittsburgh
S550
There were serious doubts there would be room for PDI under a traditional roots type charger. Ford waited for an "upside down" design (which was just announced) because nothing would work...
It STILL didn't work...
Maybe 750hp but I have serious reservations as to IF it can break 700.
Epiphany
Global
I was told the mule engines were port fuel injected only, this fits in perfect with that. No provision on the valve cover at all.
Look closely at what what would be the flywheel were this a 5.2 GT350 engine...it looks to be a flex plate which would imply an automatic. It'd be interesting to look at the flex plate for a 5.0 with the new 10-speed as word I've been given was the GT500 would be a DCT 7-speed...
zackmd1
zackmd1
Zack
I do not..! All Ford service info is available online through motorcraftservice.com
You can selecting a 72hr pass for $21, one month, and one year subscription. I use it regularly for different projects.
zackmd1
zackmd1
Zack
It certainly does look like a flexplate and not a flywheel. The 10 speed flexplate uses 4 mounting locations for the torque converter. This one has 3. I am diving back into the diagrams to see if I can bring up a picture of the Ford GT flexplate. Stay tuned...
