- Dec 8, 2014
- San Luis Obispo, CA
- 2002, 2006, 2015 Mustangs
2015-2018 Mustang S550, GT, EcoBoost, GT350, GT350R Front Control Arm Spherical Caster Bushing
J&M Products/hotpart.com has designed a new Spherical Bushing Part # 24410 for the 2015-2018 S550 Mustang GT, EcoBoost, GT350 and GT350R. Testing indicates that under track use the factory soft rubber bushings have a frightful degree of deflection. J&M’s Spherical Bushing eliminates the toe and caster alignment altering bushing deviation, and provides smooth predictable suspension gesticulation under the most demanding competitive on track experiences.
The largest in the industry 1 inch spherical bearings are made from 52100 heat treated steel/hard chrome plated ball; the bearing race is heat treated high strength steel with a load rating of 70,820 psi when most others are rated at 48,000 psi. The bearing liner is not the typical PTFE liner but made from a thin sintered bronze wire net impregnated with PTFE powder giving it great load capacity and longer wear; this is the same liner material that is used in modern ball joints for a maintenance free long life.
FEATURES:
- Available in clear, red and black anodized
- A press is required to remove the factory bushing and install the new one
- Provides vastly improved handling characteristics
- Will not flex under load
- Bearing liner is attached with a thin sintered bronze wire net impregnated with PTFE powder, same as modern ball joints.
- 52100 heat treated steel/hard chrome plated ball
- Largest in the industry 1″ spherical bearing
:clap2:
