- Dec 8, 2014
- San Luis Obispo, CA
- 2002, 2006, 2015 Mustangs
New Lower Prices:
Front Control Arm Spherical Caster (Tension) Bushings
Now Only $188.30
Now Only $188.30
J&M Products/hotpart.com has designed a new Spherical Bushing Part # 24410 for the 2015-2019 S550 Mustang GT, EcoBoost, GT350 and GT350R. Testing indicates that under track use the factory soft rubber bushings have a frightful degree of deflection. J&M’s Spherical Bushing eliminates the toe and caster alignment altering bushing deviation, and provides smooth predictable suspension gesticulation under the most demanding competitive on track experiences.
The largest in the industry 1 inch spherical bearings are made from 52100 heat treated steel/hard chrome plated ball; the bearing race is heat treated high strength steel with a static load rating of 104,000 when most others are rated at 55,200. The bearing liner is not the typical PTFE liner but made from sintered bronze wire net impregnated with PTFE powder giving it greater load capacity and longer wear; this is the same liner material that is used in modern ball joints for a maintenance free long life.
FEATURES AND BENEFITS:
- Available in clear, red and black anodize
- A press is required to remove the factory bushing and install the new one
- Provides vastly improved handling characteristics
- Will not flex under load
- Bearing liner is sintered bronze wire net impregnated with PTFE powder, same as modern ball joints.
- 52100 heat treated steel/hard chrome plated ball
- Largest in the industry 1″ spherical bearing
