Yet another "too loud with Longtubes" Thread. MACH1 Specific
Magnetic Stang
Ohio
Chad
Will do. First Im going to try out my revised tune from Wengerd. Then I may go with the Accelatec resonated X Pipe, Although I do like @shogun32 idea of opening the OEM resonator/Mufflers and addign exhaust matting
My setup was N/A, FP X-pipe, Steeda axle backs, cat delete on E85 and it was annoyingly loud. I just installed the Magnaflow resonated x pipe in place of the FP X-pipe and I can't believe how much quieter it is. Zero rasp and the tone is deeper. Cabin noise is at a minimum. Cruising speeds you can't even here the exhaust at all. I'm not sure if I like it. It's too quiet.
SheepDog
SheepDog
Colorado
Dax
Does the Magnaflow X pipe line up with the factory exhaust tubing, or is it wider/narrower? I assume you added the Magnaflow to the Ford Performance H pipe?
Magnetic Stang
Ohio
Chad
I did cut up my x-pipe to add the in Magnaflow. It lined up perfect. Only issue for me was the Magnaflow resonator pipes are 2.5" I.D. and my x-pipe is 2.5" O.D.
SheepDog
SheepDog
Colorado
Dax
Thanks. So you welded them together or used sleeve clamps?
Mikepol2
Pittsburgh, PA
2021 Mach 1, 2019 Ram 1500
Just curious, what was the theory behind putting a resonator on only one side of the H?
I had an idea what the unmodified H would sound like and thought if it was unpleasant with 1 Vibrant I could always go back later and add a 2nd. Would have been harder to start with both resonators and find that I wanted to cut one out.
gameovergt
Kevin
Lake Asbury, FL (Jacksonville area).
Kevin
2022 Ford Mustang GT California Special (A10)
Resonators! Have 2 put in exhaust.
gameovergt
Kevin
Kevin
