Wrench light for help
BrianGT2015
Iowa
Brian
2015 Mustang GT PP, 2015 Mustang Eco Convertible
Please help. Power steering got heavy. Drives fine other than that.
Jackson1320
Jaxson
2015 mustang gt
If so there’s the fuse, relay, my power steering power wire came loose but not completely so I would loose power steering in hard corners right when you don’t want to loose it.
BrianGT2015
BrianGT2015
Iowa
Brian
How heavy? Like no power steering?
I have to put quite a bit more effort into making a turn especially from a stop. When the car sits and I turn it back on everything appears normal. I put the car in drive or reverse and move. Hill start assists, service traction control, abs, and steering assist. Due to current situation I do not have the luxury of taking it apart, finding a broke part, and fixing it. Really need to diagnose buy part, do it that day. ****ing renting a house at the moment with a steep ass driveway and shitty small garage.
I removed the ground wires, scuffed the with sand paper, made sure I had good metal and contact. I am pretty sure it is not a ground.
Car drives normal other than the power steering. I bounced ideas off a friend, he said sounds like ABS module or power steering rack as well.
thelostotter
AZ
2017 GTPP
Cleaning the grounds was smart. When I had this same thing happen I needed to use Forscan to clear a code stored in the BCM. A regular code scanner won’t read or clear it. If you don’t have Forscan the dealer should be able to check for codes and clear.
BrianGT2015
BrianGT2015
Iowa
Brian
I disconnected the battery. While I cleaned the grounds. I am going to go by the O'rileys we have here. I was told they can check the codes for other than just CEL. I am disappointed I can not figure the issue. I am usually pretty good at this stuff. I believe it's the steering rack or AbS module.
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
These power steering racks actually use a rubber belt between the steering gear and the rack. It may have failed.
Try this thread, your issues sound similar:
https://www.mustang6g.com/forums/th...rking-assist-light-issue.162952/#post-3321070
Also, I put together this EPAS thread a while back to help others with any further EPAS issues. Most don’t know the EPAS unit contains an internal rubber belt (like a vacuum cleaner… LOL).
https://www.mustang6g.com/forums/threads/s550-epas-pscm-tech-accumulation.160616/
