Would you trust a used Driveshaft?
Perna00
Midway, Ga
Jacob
2019 GT converible
I’ve got a 2019 convertible with the 10r80 tranny. I’ve heard quite of people say that the one piece driveshafts are a pretty decent upgrade and I found two that people were selling. One is aluminum and one is carbon fiber. They have both been “used for one or 2000 miles“ or at least they are saying. I know that some of these drive shafts can be problematic and was wondering if it is just a gamble or something that I should run from the idea. They’re asking between $500-$700 so it might be worth it. What are your thoughts and are these a nightmare to install on a convertible. Thanks for any advice.
robvas
MI
2011 GT
I would trust a use one as long as it didn't appear damaged and the U joints are good.
Is it an upgrade? Sure, it's half the weight of the stock one, paired with a lightweight set of wheels you might see a tenth or two in the 1/4 mile
But, is it worth $700 if your current driveshaft isn't wobbly etc? Maybe not.
What are the 2 brands?
The problem with buying a used driveshaft that is already off the vehicle is, you don’t know if the owner is selling it because they experienced vibrations with it that could not be resolved. You can’t “test drive” it; if it were still in the car you could ask to go for a ride to verify if was smooth from X to Z speeds/rpm or if it produced driveline vibes.
There is also no way to tell if it was dropped or if it’s out of round (or not balanced due to manufacturing).
The other thing to think about too:
How far apart is the price used vs. the same brand new? If the delta is a small gap, just buy new - you’ll be getting a warranty with a new DS.
Also make sure that it has the correct ends to mate up to your trans flange and the rear pinion flange. There were different flanges based on model years, the transmission, and rear diff application if manual trans vs automatic…. Then there’s the 6R80 vs the 10R80, I don’t think they use the same trans flange…
I’m not saying a used DS is a POS, but you have to do your due diligence before just plunking down $$$ on any used part. Do your research on here too by reading threads about 1-piece DS’s, because some thought going 1-piece would resolve driveline vibes and depending on brand, they still ended up with driveline vibes…. There are also some brands that are known to be problematic and those have been discussed at length on this site.
Perna00
Perna00
Midway, Ga
Jacob
2019 GT converible
I’ve been reading up on them and the cf one shows rust on the linkages and I don’t trust the guy if it’s only been used a few months. The other one is actually uninstalled in box. Hardware is still new in package. It’s a dss fdsh52-a (fits my 10r80) and seems pretty legit. I can get it for between $500-$600. It says id need to install a lockout kit though.
SCP440
Oxfordshire UK
2019 Mustang GT, Jensen Interceptor, Ford Capri 3.0 Ghia
On some other makes of cars a one piece driveshaft can cause vibration because it is unsupported especially on Automatics. I was having a new one made for a project car aa couple of years ago and I asked about a one piece because it was going to be cheaper and he said he would not guarantee it if fitted to an Automatic.
John S
Novi, Michigan
2022 Mach 1 HP
Only if you get a warranty to return if there are vibrations. 10R80 contributes to System balancing concerns, more than other transmissions, and sometimes there are high speed harmonic vibrations in one-piece driveshafts that are difficult to resolve.
RNM
2022 Mustang GT
I wouldn't trust any driveshaft from DSS.
SnowFox
Mn
Grabber
2022 GT, 2017 ECOboost, Saleen S351
Some used things are fine to roll the dice on. Personally Driveshaft wouldn't be one of them.
If something is wrong I at least want peace of mind that I have company I can hold accountable (to some degree)
icecreamtruckz
2018 GT350
Really? Seams like they are offered the most places.
In the 350 forums I have heard nothing but good for QA1 and a few issues with DSS. This may be nothing more than coincidence. But it makes me think if multiple voodoo cars were able to use QA1 without any vibration or harmonics issues, they should be good on anything else.
