Will a 12" Sub + Box Fit in the Trunk and Maintain Audio Fidelity?
Daze
CO
2015 GT PP, Race Red
This may be a silly question, but I am seeing conflicting opinions on what Sub size to use in the trunk. Conventional wisdom tells me a 12 inch sub + box will fit fairly easily, but I don't know much about where to position a sub and the impact that has. Can a 12 inch sub fit in a "good" spot, or do I need to start looking at 10 inchers?
h65
Pacific NW
Harry
1965 Fastback, 2015 GT Premium (CO)
Yes, it will fit. No it will not maintain audio fidelity because 12".
Go with a 10" for tighter bass and fidelity. Plenty of space on one hand, but then again it's a small space to have to fill with sound.
neozeric
Central Florida
2015 Mustang GT Prem
Depends on the music you listen to and the kind of bass response you want. A 10 inch can sound great and requires a smaller enclosure. You can even get one that goes up against the side or put it in the spare tire well or up against the rear seats. A 12" will fit as well. Heck some guys are putting 2 15s in their trunk. If you get a 10 or 12 that does not require a huge enclosure then you can easily hide it. I am personally putting a 12" in the spare tire well.
Daze
CO
While I don't know about positioning, I do know about sub properties. 10" doesn't necessarily have more fidelity by nature. The "smaller diameter the bass the tighter and punchier", and the "larger diameter the bass the more volume and muddier" is only a highly basic rule of thumb. Less diameter can be easier to make "tight and punchy", while more diameter makes it easier to move more air, creating more volume. However, there are 15" subs that can be clearer and punchier than 10 inch subs, depending on the quality of the sub and what it was designed to do.
My point is, having a 12 inch vs 10 inch diameter will not intrinsically ruin audio fidelity. Why not go 8 inches if smaller is always better and more accurate?
If you have some sort of concrete proof that 10 inches is the sweet spot for car audio, I would like to see it (and no I am not being sarcastic, I really would), maybe all my research was wrong.
But thank you both for answering my question! I am likely going to put a sundown SA-12 D-2 in the trunk :).
stoli
Fat Guy Racing
Lakeland, FL
'15 Black GT/PP
It all depends on the type of sound you want and the manufacturer. If you are after spl style bass, Sundown makes some good 8" subs for smaller spaces, but spl is where bigger is pretty much always better. If you want more clear, tight bass I prefer JL 10" or 12" subs...
Whatever you choose, check the specs for what the recommended size for the enclosure is, ported and sealed. Often the spare tire well is way too shallow for a proper setup.
Cream Puff
Canada
in the market
Incorrect.
A common misconception is that larger woofers mean less accurate bass, a properly designed enclosure for any decent quality (or sized) woofer will produce a musically accurate response.
The place where you may run into trunk space issues is with certain drivers that require a very large box volume for their recommended specs. For example the alpline type R 12's require GIGANTIC volume for a ported box, and would essentially take up your entire trunk.
Look at the Hertz Hi-Energy line, they can work in very, very small enclosures. I have a pair of 12s that is in a smaller ported box than I could have put a single alpine in.
http://www.hertzaudiovideo.com/hx-300-d/
spec sheet
http://www.hertzaudiovideo.com/wp-content/uploads/2014/05/Hertz_HiEnergy_hx300d.pdf
Daze
CO
I was not intending on putting it inside the well, I was thinking about putting it to the left or right where there is the most headroom. I was going to put the amps in the wheel well. Is that a good idea?
Daze
CO
Incorrect.
spec sheet
I'm glad you agree with me about the sub size not being the only indicator of fidelity, I guess my research was correct.
As for the sub itself, I am pretty much already sold on Sundown, lots and lots of research to come to that conclusion
Cream Puff
Canada
in the market
I've been involved with the industry for going on 15 years now (god that makes me feel old).. i've seen SPL winning cars with 10s.. and SQ cars with 18's.. its all in the setup
:thumbsup:
stoli
Fat Guy Racing
Lakeland, FL
'15 Black GT/PP
Those box specs are barely bigger than the subs!
Putting box size aside, just how well do these perform?
Cream Puff
Canada
in the market
I cant speak for the sealed enclosure as i've not tried it.. but the ported one sounds fantastic, running off an alpine pdx amp :D
gsxr1300
MA
Jason
2023 Mach 1 2015 Mustang GT PP (Sold)
Check Out Stereo Integrity MKIV it's designed for a .5 box.
Mark5825
Mustang
Mustang
10" Alpine Type R
Not sure where you want to put them but these 10's hit pretty hard RMS ~1000 Watts. Spare tire accessible with a bit of work.
nelzzz
United States
2015 Mustang GT
Mark5825
trunk looks great, did you change the head unit? or line converter?
Mark5825
Mustang
Mustang
