Anyone ever put 2 12 sub boxes in the trunk?
Lowkeyslow
California
David
2019 Mustang GT
OF5.0
Pittsburgh
Scott
2022 Shelby GT500 CFTP
So I ordered 2 12s. Checked the measurements and I think it’ll fit but I’m not entirely sure. They come in a box preassembled and this is the link. https://www.skaraudio.com/collectio...-packages/products/evl-2x12d4-rp2000-skar0anl
h
as anyone put 2 12s in their trunk without using zenclosures box? Wanting to know any input on your guys setups. Thanks
That box, based on Skar’s specifications for two 12” EVL woofers in a ported configuration, should be 4 cubic feet. That’s huge! I didn’t look at the box dimensions, but it may be difficult to get the box in the trunk.
m3incorp
Georgia/Colorado
James
If the height is more than 16" you won't be able to fit in very far into the trunk. Mine is 16" I have to jam it in to get in to where it almost touches the rear seats. I couldn't find the enclosure dimensions on Skar's sites. I notice all Skar equipment is rated at 1 ohm to achieve those high wattage they advertise.
Edit, I see on amazon they list the height as 15.75" and 35.5" wide. You should be OK with getting it in there but very little trunk space left over.
That sucker weighs 150 lbs....yikes.
FamilymanGT
Proctorville, OH
2019 Mustang GT
I am gathering things for my system install. I have found very few dual 12 boxes to fit. I am going with a single 12. The 16”height is only 26” wide unless you start cutting up the car. If not, you will be using all the trunk space.
OF5.0
Pittsburgh
Scott
FamilymanGT
Proctorville, OH
2019 Mustang GT
That box should work according to the specs. I like the zen enclosures as well. Personally, I’m doing one 12” Punch P3 and custom fabbing the amps and interface into the box/rack. Buying a proven ported prefab box and working around that.
m3incorp
Georgia/Colorado
James
I also went with a single 12" and it barely fits under the shelf and still takes up quite a bit of trunk real-estate.
FreePenguin
Ohio
Donald
17 mustang
Will try to find my post on boxes
