Why not a square 305 setup on Base GT350?
Madlock
All Over
Lots
For the same purpose all staggered-width fitments serve, to help establish over/understeer balance.
Hack
Minneapolis
Mustang, Challenger
Bring it to BIR and we can play with the P-cars ;) Go for a set of the N4SM R spec wheels and you can either run a 295/315 or 315 square Hoosier setup for the track and save your PSS tires for the street.
I'm going to trust Ford's setup - at least for the first time I go to the track. I really liked BIR when I was there before, and I plan to get there this coming year as well. :cheers:
cloud9
Sioux Falls, SD
2019 Mustang Bullitt
Check into Nordstern Porsche Club events. They are a blast and you get a ton of track time. I won't be able to make the NASA Time Trials up there over the 4th as my youngest is getting married, but that's a great event too.
As far as trusting Ford's setup, yes it's good if you plan to run the stock tires. Hoosier R7s will be faster and about $400-$500 less per set though.
nastang87xx
San Diego, CA
2016 GT350 Track Pack
What I don't understand is why such a SMALL stagger on the tires from the factory. I'm starting to get more and more convinced of running squared for racing.
MAV
Arkansas
2016 Shelby GT350
I would REALLY like to do 305/30-20s all the way around on 11" wheels. N4SM says that a 35mm offset on all four wheels would be required to fit front and back properly. The 10" wheels they offer do have 35mm, but not sure how those would fit with 305s.
krt22
Just enough to keep the car under-steering. Overall it must be pretty neutral or slightly prone to under-steer, so perhaps just a small stagger was required to it that way.
krt22
I wonder if that will poke a bit in the rear since the R wheels are +56 at 11.5" wide and already seem to poke some. Might need a spacer up front as well with that high offset (R front wheel is +24)
Stig'sBaldBrother
GT350 White/blue, track
I decided to go with Forgestar 19x11, 56mm offset on all four corners with 29mm spacers on the front. I'll be running 305/30/19 for the track, probably NT-01s.
In fact, I already have the rims at the house but no car to put it on. :doh:
Stig'sBaldBrother
Which Forgestars?
F14s. They were on sale for 35% off. Got em shipped for under $1200 for the set. Not my favorite wheel, but good enough for the track.
Bossing
attacks tracks
So. FL
Just can't get enuff!
Nice.... what measurements/dimensions did you get for fronts and rears? What tires are you mounting as well? New TPMS too?
1mic
2 mph so everybody sees u
Mountain View, CA
God bless America, all 8.4 liters -Randy Pobst
Here let me help you:
http://enkei.com/shop/racing/rpf1/
If you are doing some road course driving, I would suggest 18's. However, you will have to do research if the stock brakes will fit in the 18" wheels.
If they do, I would go with the 18" 10.5 wide wheels (weighs in at 19.05lbs, that is light as hell!). I would for sure go with the RPF1's if I owned a GT350.
nastang87xx
San Diego, CA
A lot of us are saying probably not a good idea even if they do fit. The lack of clearance is scaring some of us, say if a rock got lodged in between the caliper and the wheel or something. Is it nit picky? Yeah, probably. Is it a reasonable concern? Eh...maybe, too. Z06 and ZR1 guys have run 18's on their cars before but some have run into those damage issues too.
krt22
Not sure why you would want to run 10.5s when you can easily run 11 all around.
