Whipple and OPG question
BustedKnuckle
Tn
16 GT PP
I will be doing OPG and sprocket in preparation for a Whipple. I'm considering throwing the OPG and sprocket in and reassembling the car for now. Then do the Whipple later. How much time am I wasting? Should I wait and do the entire job at once?
evo8904
I'm a member???
Tampa
Luther
2017 Ram 4x4
I would do it all at once.
rio16
MAD_50HH
Bay Area SJ, CA
Rio
2015 Mustang GT Whippled Competition Orange
Did mine at the same time.
zaquhree
Orlando
2015 S550 GT
Depends if you're doing it yourself or not. Might as well bang it all out at once
stealthfrc
CT
2017 raptor, 99 corvette, 2015 PP mustang gt
you wouldn't be wasting to much time. the only thing you would really be doing twice is draining and filling the coolant and removing a few lines. it would be good to spread out the work load a little instead of trying to do it all at once.
ahl395
Allan
Personally I will be doing my OPG first and then FI later. Since It'll be my first install of this caliber I want to make sure everything is good from the OPG installation before going into the FI, otherwise It'll be harder to diagnose any potential (but rare) issues.
Just my personal opinion.
supercharged680
Dubai
2016 Mustang 5.0 arriving in septemebr
Im in the same boat as you, which brand are you planning on going for?
BustedKnuckle
Tn
16 GT PP
Thanks all for your input! Much appreciated!
BustedKnuckle
Tn
16 GT PP
I have not decided on brand yet. By no means want to beat a topic but are there other manufactures aside from MMR?
boosted4life
Fort Worth, Texas
2015 mustang gt
Dat Boi Kumar
Rosharon,Tx
Chad
2015 Comp Orange Mustang GT
I did mine after I installed the whipple, its not much more work with the whipple already on.
The Game
Virginia
Garrett
2015 Mustang GT PP
I installed mine when I installed the Whipple. Crossed my fingers, hoped for the best. And all was good lol.
esacteksab
CO & KS
2015 Mustang GT
I did them at the same time. You don't actually need radiator/water pump/alt to know if it'll start or timing is off...
Put the front cover/damper back on. Started it up -- found out I did it wrong. Took damper/cover off, re-timed it, cover/damper, started it. Started/idled fine. On with the Whipple install.
If you have the time, this is the path I'd take because you've already got it partially disassembled so you're a part of the way there. If you're limited on time, do one, then the other. I wouldn't wait to start the car for the first time after the Whipple install. That's a lot of work to get back to the front cover.
