Whipple 2018 Results
Whipple SC
Fresno
after Countless hours and combinations tested, here our the results of the new Stage 2 Whipple system. Tested with 91 octane fuel, 100% stock vehicle including stock Cat back. Ambient temp was 74deg F, 10 speed auto, 5th gear pull.
Triple intercooler is showing incredibly low IAT’s and blower is barely turning. 3.75” standard pulley making 12psi of boost.
Hivel
NorCal
Mustang GT
Nice. That Stage 2 is on my short list.
Thanks,
Tommy V
Brookly park Md
Tommy
On 91 octane???What kind of timing u seeing??
Angry50
Jacksonville, FL
Fred
2017 Shelby GT350
91 octane in 5th gear? am i wrong in thinking in the 7th gear 1:1 and on 93 octane this would be 770-800whp?
Whipple SC
Fresno
whats is all included in a stage 1 vs stage 2?
High flow fuel pump, smaller pulley and more aggressive cal. Cal essentially has rpm, 7800 vs 7500 and more aggressive shift schedule to maximize those rpm ranges.
Whipple SC
Fresno
7th on our large rollers is way to high in mph. I ran it once that way early and it showed slightly more torque from 3-5k but leveled off to very close to same. Same with 6th.
gimmie11s
SoCal
Murica!
Original post says this was done on the "standard 3.75" pulley.
Can you confirm which pulley was used on this pull and which pulley is used in the stage 2 kit?
Many folks very excited about this kit!
thanks!
Angry50
Jacksonville, FL
Fred
2017 Shelby GT350
just out of curiosity did yall replace OPG/CS or forsee it as an issue?
robw_39
Atlanta, GA
So I am confused I ordered what is being called the Stage 2 kit by the resellers their description sounds nothing like what you are mentioning in this post... from what I am seeing the Stage 2 kit is Stage 1 plus a bigger 132mm TB and that is it...
So is WHP-WK-2625B-STG2 actually a stage 2 kit or not?
1crazymach
Modesto Ca
Simon
2020 Race Red GT 500
I believe what you're referring to as the stage 2 is a stage one with the upgraded throttle body. That's what I ordered in order to be able to still keep warranty. I was told you can upgrade the throttle body but have to keep everything else Whipple so that you can keep warranty.
robw_39
Atlanta, GA
That is what I am guessing but things are a little misleading when the part number has STG2 in it...
