Which mod should i go with first
ss27gogeta
Indiana
zach
2020 mustang gt
They fit perfectly fine. I have ran them with both BMR Performance Springs and now the Handling Springs. No need for a spacer on the front as long as you get the right offset (which most of the Mustang vendors offer). Only reason I went with a 325 was to get the Indy 500's, I previously had a 305 on the back in the Nitto and it was nowhere near as good as the Indy.
Are you running your 325's on an 11 inch rim or wider?
SSG 5.0
2017 Mustang GT
Nitto 555R?
ss27gogeta
Indiana
zach
2020 mustang gt
If things weren't the way they are now, I would have recommended a good tune. It really woke the car up for me and made it perform like it should. Night and day difference. And then if you got it tuned for E85........
I would love an e85 tune I got e85 everywhere around me but with the car being new I want to put a few miles on it before I think about something that will void my warranty.
SSG 5.0
2017 Mustang GT
I drove my car 10k miles just to check if the car makes an unusual noises before adding a supercharger. No issues so far for over 2 years, but this is not DF car though.
Your car is DD?
ss27gogeta
Indiana
zach
2020 mustang gt
Your car is DD?
I was think of doing the same drive the car for a few thousand miles if nothing gose wrong I would probly at least get an e85 tune. or possibly just go straight to a supercharger haven't quite decided yet I have a while before I get there. and Yes it's my summer dd. although I do have other vehicles to drive a ranger for a winter beater and a 78 f150 that I'm hoping to finish the restoration on this summer.
RazzaRossa
West Coast of Florida
Ron
2019 Mustang 6spd GT Premium PP1
Do nothing first, drive it, get a feel for what you, and it, can do before you spend a wad of cash on internet suggestions. You don't know what you don't know.
SSG 5.0
2017 Mustang GT
I knew my car is not a DD and that’s why I wend Nitto 555 R. All the members here said they hooked even on 1st gear and they’re all right, but then of course, I’m not pushing high hp like some of these guys.
Nuked
Morgantown, WV
2016 Triple Yellow GTPP w/Recaros
Norm Peterson
corner barstool sitter
Norm
'08 GT #85, '19 WRX
So I can't resist the urge to mod my car my wife thinks I'm crazy to swap parts on a car with only 500 miles on it. But I told her it's just who I am I got to tinker🤣.
So I'd love to do HP mods but honestly I can't really even fully use the 460hp it comes with in stock form and I'd like to maintain my warranty on the engine for a while. so I'm thinking of starting with better tires and rims or should I start with the suspension first. I've got 235 all season tires not the best for traction. I have 2k I'm willing to spend right now where would my best gains for the buck be spent. My car will mostly be street driven in the summer and I'll take it to the drag strip a few times a year thanks.
Wider wheels with one of the better summer tires in wider/lower profile.
Save the 235/50 all-seasons for the cooler months that you continue to drive the car. They should even tolerate light snow.
Norm
Bandi
Daniel
2019 Mustang GT
I was hoping someone else would chime in about the square vs staggered setup. I didn't feel like going into a whole argument and explaining the pros and cons. I spent a lot of time deciding between the two and the shop I bought my custom wheels from reassured me staggered was the better option for a mainly street car.
Even if the rears wear faster you're not spending more money. You just end up also staggering your tire replacement costs so it works out the same. And wider tires always cost more, so of you're not tracking it a lot, wide fronts end up costing you more even if you rotate.
I went with a staggered setup regardless of when tires need to be changed and such.
Generally speaking, it's a performance car. It's a car that's going to get driven. I would expect to have to replace things regardless.
I'm not really too concerned about when I have to replace the tires. I will eventually have to replace them. Whether it's "8 months" or a year and a half, the money is going to get spent.
If the spending of money in general was going to be a concern I wouldn't have bought the Mustang to begin with let alone any performance car. Just my two cents on the matter.
kai20035
Ontario, Canada
Peter Who
2016 Ford Mustang GT
If you don't want your car to end up in the "Mustang's Fail Video" I would highly suggest getting the Steeda stop the hop kit or something! Even with having wider tires won't stop this and modding the undercarriage was the first priority for me. I got the Steeda subframe brace, IRS bushings, subframe bushings, differential bushings and vertical links which wheel hop is non existent! Once you've got this done and then perhaps going with CAI like Injen Evolution/K&N to keep your warranty and get some extra power. I also got the Pedal Commander to help adjust my throttle response which connects to your gas pedal which is awesome too!
Doug V
Central Valley California
Doug
2020 Mustang GT
Jacking rails. If you plan on doing regular work.
larr12
Alberto
2020 Mustang PP1
Xzavior1818
ohio
Anthony
2015 SCION xB, 2019 Mustang Gt
Considering a catch can but do they really work? Why a “must”? Thanks!!
Modern engines with the modern thin oil has blow by and if you drive it hard you'll experience more of it it. Oil goes back into the crankcasr to be burned off during combustion. This can gum up your intake, valves and hinder performance. The oil I dump out of mine is nasty, burnt and something I don't want to feed back into the motor. So by my experience they do work.
