Wheel fitment. Help
Hooligan
Columbus Ohio
Alex
2017 Mustang GT
Hey guys,
So I just lowered the car with the cj pony parts springs. Lowers front by 1.5 and rear by 1.0
Now for Christmas I got a set of SVE wheels that are 20s instead of my factory 19s. What size tires do I need to run? Or is the car to low now for 20s? Do I need spacers?
Im attaching picture of wheel specs
Juantrickpony
Ohio
15GTPP
Too low? That’s subjective on here. I don’t think so (if you’re not tracking it, which wouldn’t be smart on 20’s anyways).
Take a look at the sizes LMR includes with their packages. They’re usually pretty safe and still a decent ride (profile wise). Looks like 255/35 for the front and either 275/35 or 285/35 rear.
https://lmr.com/products/mustang-sve-xs5-wheels-15-20
Personally I’d get wider wheels but these should still look good. Post pics when you mount em up. Here’s a pic from LMR. :thumbsup:
MidwayJ
Dallas, Texas
Jay
2019 Mustang GT Coupe
Agree with the previous reply. You also asked about spacers. With those offsets (+20 front, +35 rear) you will not need spacers.
fmc_smt
Cottonwood , Arizona
Might consider spacers , running velgens with following specs , on a sportine drop , so approximately 1.5 in front and rear fronts 255/35 20 wheels 20x9 +35 rears 305/30 20 20x10.5 +45 . No rubs and set flush ..
MidwayJ
Dallas, Texas
Jay
Why would he consider spacers? With +20 offset his front wheels will sit 15mm further out than yours, and his +35 offset rear wheels will sit about 4mm further out than yours (taking into account your wider wheels).
fmc_smt
Your right ..... the offsets always screw with my math in my head .
TopJimmyCooks
Raleigh, NC
James
2017 GT Prem PP; 2019 EcoBoost Prem
Hey guys,
I’m sure you are already planning to do this, but lower aspect ratio in order to keep Speedo accuracy. I don’t know what you have on there but this calculator will help you decide between 30 or 35:
https://www.discounttire.com/learn/tire-size-calculator
Also, I’m always posting this next link (people are probably sick of it) but I think it is helpful: https://motoiq.com/how-to-properly-select-and-size-tires-for-performance/
Hooligan
Columbus Ohio
Alex
2017 Mustang GT
just out of curiosity. I did the speed calculator you sent. I would need to run 30. But for the fronts they don’t really sell the same tire I’m looking for in a 30. Would it hurt to run a 35 in front and 30 in the back?
TopJimmyCooks
Raleigh, NC
James
No, but it might mean that the relationship between the rear and front ride height changes. Best is to use that calculator to see. In my case, I calculated the tire sizes to: 1) keep the speedo close to OEM, and 2) keep the rear tire height difference to the front tire height similar to OEM. I was coming from 255/19/40 and 275/19/40. Going with 275/19/35 and 305/19/35 did the trick. Depending on the height difference you might want to raise/lower the front or rear if you are able. I’m not familiar with what you bought, so I don’t know if you can. But since your front wheels are narrower by a good bit, there should be no issue at all.
Here are a couple photos of before and after lowering about 1”. You can do the math in the calculator to determine the height difference of my tires to help visualize how whichever ones you are shopping for might fill the fenders.
MidwayJ
Dallas, Texas
Jay
I think you'd be fine with 255/35 front and 275/35 rear, or 285/35 rear. The tire diameters of 255/35/20 and 275/35/20 are very close to those of the stock GT PP1 setup of 255/40/19 and 275/40/19. I don't think it's necessary to go to 30 profiles unless you're using wider tires.
Juantrickpony
Ohio
15GTPP
If your Ohio roads are as crappy as my Ohio roads I wouldn’t recommend 30 series.
