Wheel and tire question. Help!
ugstang17
unknown
none
305/30/20 20x10.5 +45mm offset rear
255/35/20 20x8.5 +35mm offset front
Its just that simple...
fmc_smt
Cottonwood , Arizona
Same set up , but lowered 1.5 front 1.3 rear
Sleipner
Sweden
Mustang GT 5.0 Fastback
20x10.5" +45 305/35 Stock suspension
Wouldn't have it any other way.
MuIz--sJ-coNFeqOsJyhOWcz7SIAMuV7Saq1vW4UoQW-N8qdJD7r54Z0IuQ-yLV-7pVrS-T-rDYyvHHSwM=w1010-h757-no.jpg
k9xrmhgWEM2T8wPL3mesSbTea7ZgqN9eEuHC0_fYFWpkU3gS-GKL3L1tzwhiy6dH3xXV8d3GxWz_N0Acg8=w1010-h757-no.jpg
Would 295/35/20 on 20x10 work on 1.1" / 1" lowering F/B?
Sleipner
Sweden
A square setup?
That should be fine depending on what offset the wheels are.
Yeah, i'm aiming for a square setup.
I've been told from some that 295/35/20 might be a bit too big of a tire, and go for 295/30/20 but that has a much smaller diameter than stock 275/40/19 which people put up front (275/40/19: 702.6mm, 295/30/20: 685mm).
If i go for 295/30 in the front, the difference between stock is (255: 686.6mm and 295: 685mm) but I was hoping for a square setup both for the looks and to be able to rotate tires. This also gives me a SMALLER front tire which is not what I'm looking for by going up in wheel size.
For reference, 285/35/20 has a diameter of 707.5mm and works in front with ET35 acc to at least BrantMcE.
The problem with 295 is that it's wider....
I'm planning for going for a ET37-38 to tuck it in a bit but i don't know how much backspace I have compared to the stock wheels? The back should be good, but how about the front struts? How much "closer" can you go compared to stock 255/40/19 wheels?
BlownGP
Houston/Baton Rouge
Steven
Pontiac, Ford, Dodge
I really think 30 series tires are too small for these cars unless you are slammed on bags or coils. That's just my opinion though. lol
Again depending on offset, there is plenty of room for a 35 series tire with a moderate drop. I plan on dropping mine with the BMR minimum drop springs once I find some struts.
I will say this. I put my 20x10.5" +45 wheel on the front of my car just to see if it would fit. And it hit the front struts. Not by much but it rubbed it. So with that said a +40 probably would clear it.
So 20x10 with a ET37-38 will be fine. I don't see why a 295/35 would be a problem. I probably should have went with that on my front 20x10 because the 285/35 looks kinda short to me. lol
Sleipner
Sweden
Ok, so just to clarify; you run a 20x10.5" +45 305/35 in the back and 20x10.5" 285/35 in the front? :crazy:
