What's your tranny run?
likeaboss
Baltimore, MD
2020 Corvette Z51
So 70-90 degree difference between Track/Tech cars that're running on track conditions (131f) to normal driving (200-220f). That's not comforting at all. Why the F*** would Ford do this?
So they could sell a $49,995 GT350 and poor packaging choices hence the 17 changes. It's a clear screwup with no official fix in sight outside of trading for a 17.
_M_
Planet Earth
A Mustang
Yeah. That doesn't even seem possible. I would assume the normal operating temp would be much higher.
_M_
Planet Earth
A Mustang
when I went to track attack, the tranny temp on track pack gt350 went up to 131F.. but we're talking about running trannies lets keep it on subject :lol::thumbsup:
Leave youporn out of this. Ha
How were they monitoring this? Do the track packs have trans temp available on the menu?
Side_Pce
NY
2016 GT350
Yes. Can modify Tech pack computers to display this as well.
JN66
British Columbia
2017 GT350R, 1966 Couple (347 Stroker)
242f on a normal drive home today. 45 minutes or so.
  • Like
Reactions: TDC
montreal ponies
Montreal, Canada
‘17 Ruby red GT350
Were you up in the mountains ? That's pretty high for a 45 minute drive.
What was the temperature like ?
JN66
British Columbia
Nope. It was a drive from the ferry terminal actually on Vancouver island. No mountains at all. Temperature was 22 degrees C out. Really high man. This car overheats like its its only job.
superman07
columbus ohio
2016 gt350
I can hit 240-260 in 45 minutes pretty easily when it is hot and humid. Put three people in your car and just roll at 80 do a couple hard passes and see what happens.
superman07
columbus ohio
2016 gt350
why do you think they thought it was slick to remove transmission temp from the digital readout. They knew damn well it was going to be a completely different set of operating conditions regardless of track use.
GT_Dave
NE Illinois
1970 Mach 1 408EFI , 2016 GT350
Why?
Do you think that Ford would readily allow a temperature display for a condition that would go out of control so easily?
That would create more of a service problem than what they have now. Keep in mind that only a very very small percentage of Base and Tech Pack owners are monitoring the transmission temperature, including the few of us that turned on the gauge feature. If all of the 3500+ cars had that display visible, there would be a lot more warranty complaints they would have to address.
_M_
Planet Earth
A Mustang
Did I miss a thread on how to display it or do I have turn it on through OBDII
_M_
Planet Earth
A Mustang
the other question i had if someone can answer it is what is the normal operating temp for this trans and what are track pack and Rs operating at?
Tank
9/11 - Never Forget
Above the Notches
G0853
Tank
9/11 - Never Forget
Above the Notches
G0853
With ambient temp 73, no uncomfortable humidity , operating in low end of power band (3,500 - 5,500 with bursts into around 7,000 rpms occasionally, transmission got to 243 for extended period.
  • Like
Reactions: TDC
