Whats next? Sraying NA
Friesian
Alberta
2015 Mustang GT
What is my next step engine wise to make more power. Pmas wai, gt350 intake, catless headers, 93 tune..
Im guessing cams next .but probably a big expense
Zelek
Hutto, TX
2021 Mustang Mach 1
Supercharger or Turbo.
EFI
Masshole central
5.Br0
Not much left besides heads and cams.
Maybe a CJ with dual TB, but you're not going to gain that much and gonna cost you quite a bit.
Strokerswild
Shallow and Pedantic
Southern MN
Things With Wheels
Heads, cams, CJ and TB....
And stroke for more cubes.
Zelek
Hutto, TX
2021 Mustang Mach 1
Guess you didnt read the NA part
If you'd rather waste a lot more money for underwhelming results, then stay N/A and go with cams.
smann
Toronto
2016 GT PP
Sraying N/A is expensive.. Not worth it IMO.
But if you want to sray N/A, Heads and Cam.. Maybe port the IM or get a CJ
Friesian
Alberta
2015 Mustang GT
Kinda what i figured.. will stay NA untill I can afford a paxton
El_Centenario
5L V8PWR
Apple Valley , CA
David
'15 Mustang GT Triple Yellow
I'm also at that point and I have decided to stop with the engine mods until I have enough to add boost. There isn't much left bang for the buck staying NA with the mods you already have. Might want to consider loosing weight, wheels, brakes, drive shaft, and other weight reduction mods. I honestly do not see any benefit in building an expensive NA car if I am NOT competing in a certain NA class. If it's just for fun, stop now and save for boost.
gameovergt
Kevin
Lake Asbury, FL (Jacksonville area).
Kevin
2022 Ford Mustang GT California Special (A10)
nitrous! j/k. suspension mods. No sense in more power if you can't get it to the ground! Highly recommend Steeda Struts/Shocks/Springs/IRS Braces/Bushings.
kiszl
Miami, FL
Kevin
Tripple Yellow 2015 GT
E85
Friesian
Alberta
2015 Mustang GT
Yes i agree. Already have driveshaft and full bmr catalog
Notagain
United States
yellow 2016 5.0 totaled white 2018 A10 now
CONVERTER!!!!!
worth like .5 second on NA cars.
a Circle D 5c is next on my list to go with my cobra jet flex fuel setup.
Itll be the best 1200 bucks you could possibly spend right now before boost or nitrous.
