Jaymar
- Jun 15, 2018
- Portland, OR
- Jaymar
- 2022 GT/CS - Rapid Red
Coyote doesn't have the same map support EcoBoost does, completely different control strategy for the ECU. And the means to check for a factory tune via checksum most certainly exist but as far as I know are not currently used by smog check. Most that I know about are checking IM readiness which gets them very close and still accommodates CARB approved mods.I myself don't see an issue with a tune, just so long as it doesn't shut off the rear O2 sensors. It's my impression that in one of the strictest states for emissions testing, CA where I live. When they read your OBD II port, all they are looking for is that all of the required monitors are reading "Ready". Beyond that, there is the visual and if you have a E.O sticker for that aftermarket equipment, you won't get dinged.
I highly doubt that the emissions testing facilities, has the equipment that has the capabilities to read the code and know that it's not stock. I don't think that even a dealer service dept has that capability.
I don't know why our ECUs can't have multiple maps, that can be changed on the fly. I came from the Ecoboost platform and there, you can have multiple maps loaded and all you have to do, is press the up and down arrows for the cruise control, with the cruise control off. Press a button, the tach needle will move to the 1,000rpm, 2,000 rpm, 3,000 rpm, etc. 1,000rpm = map 1, 2,000rpm = map 2, etc. IIRC, you can have around 5 maps in the ECU at one time, simple. No need to get your handheld device and reflash to another tune, unless you are adding another map.
