What Fuel Should I Be using?
hunterrrjohnson
new jersey
Hunter
2019 Mustang GT
I bought a 2019 Mustang GT from a dealer. Car was originally from Alabama. Came with Headers, Intake, and a Tune.
I’ve been putting 93 in it for about a year now and just seen a post abt somebody’s AFR reading 9.8 at cruising and Idle, and 20 at Deceleration. People wear saying it’s on an E85 tune and he shouldn’t be running 93? Was wondering best way to figure that out? Or how true that is.
KeyLime
Pleasanton, CA
Lenny
2021 GT/CS Convertible
I'll have to check, but I think 14:1 is the typical AFR for gas motors.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
If you are on an E85 tune I can't see you driving for a year without it throwing a check engine light.
NGOT8R
Adrian
2019 Bullitt
9.8 is indicative of an E85 tune. I just switched from my E85R tune to Flex and the car runs like crap. I had to do it for a road trip and I can’t wait to run the 93 out and put it back on E.
K4fxd
NKY
If it's pulling 30% fuel it should throw a mil in 10 miles or less. Maybe OP is ignoring it
NGOT8R
Adrian
2019 Bullitt
Could be. I met another member on here in person, who had bought a tuned car with no device to accompany it and was running 93 octane with 9.8 showing on the gauge. His CEL was on too.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
What’s your AFR at idle and while cruising? Hows the car running with 93? Whats your cruising gas mileage?
Theres no real way to be sure if you have a 87,91 or 93 tune (93 is most surely ok), but we can probably rule out E85 based on these other things.
black22gt
TX
Trigger
2022 mustang gt
AFR tells part o' the tale. As others have stated, itll target 9.8:1 if it has an e85 tune, otherwise it targets 14:1 for gas. Now whether that tune is 87/91/93 compatible or just for 93 is trickier without a tuner to ask to check. My thoughts are if someone tuned it for intake and headers, they probably did a 93 to get the most power from the tune. Could be wrong, but thats the safer/more expensive assumption.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
ok, so you seen some other post for 9.8 AFR. That's for E85.
20:1 AFR is decel fuel cutoff ... one of Fords brilliant ideas.
What's YOUR AFR showing ?
The Demon
Brett
2022 Mach 1 N5809
Gasoline?
