Vlad Soare
- Jan 21, 2020
- Bucharest, Romania
- Vlad
- 2020 Mustang GT 6MT
Hi,
In know how oil grades work - the lower number is the viscosity at low temperatures, the higher number the viscosity at working temperatures, lower on the left side is good in winter, higher on the right side is good in extreme heat or on the track, and so on. I know the general theory.
But what exactly do those numbers mean? In a 5W30 oil, 5 is the viscosity at low temperatures. OK, I get that, but what does that mean? Five what? Pascal*seconds? Poises? Centistokes? Or what? And what exactly does "low" temperatures mean? How low? Try as I might, I couldn't find a straight answer, something like this: "an oil with a rating of 5W30 will have a viscosity of 5 <insert measuring unit here> at xxx degrees Centigrade, and 30 <insert measuring unit here> at yyy degrees Centigrade". All I could find were graphs showing the ranges of temperatures over which each grade is meant to work well. But those don't answer my question.
We all know that lower is thinner, higher is thicker, lower is better in winter, blah blah blah. But that's just a superficial concept meant to describe the basic idea in layman's terms. What's the exact definition of those numbers?
Thank you.
Thank you.
