IPOGT
2021 Mustang Mach 1 Velocity Blue M6
I’m in upstate New York but if I’m ever in that area and need help I’ll have to check it out. Thanks
Didn't post earlier, but I had one of my PP shocks from Ford's Street Performance Kit leak and I replaced with Bilstein B6 on all 4 corners. Now I do not miss magneride at all. 100% totally happy and everything I have wanted my car to be. Well, there are days I wish I had manual, but not always.
16Fastback
RMR 8985
Pennsylvania
Stephen
2016 Fastback , 2009 Ranger 4x4
Got Anderson composite deck lid on.
It's recessed in farther in than I like.
Tail light trim looks good ,double sided tape doesn't stick well to the carbon fiber hope it stays on .
ER95
Installed:
White rear decklid pony
Tweeter speaker trim
Door Speaker Trim
AC Vent Trim
Billet Dead Pedal Trim
Ford Performance plaque
Billet Hood Release
Interior Trunk Pony
DmanDmythDlegend
Virginia
David
2019 mustang gt pp1
Dropped even more funds into my impending transformation of the mustang. Decided to go custom tune with the new whipple kit when it gets here, so got id1050x injectors and bap, nguage and lund will be handling the tune. Also got the 2k no bolt axles. Also got the cervinis gt500 hood that will be painted locally.
Assh
NC
2019 Race Red GT
Finally replaced the B&O subwoofer with one that performs (and fits in the box). I bought a MB Quart DS1-254 shallow mount sub. I filled the box (loosely) with fiber fill and mounted the sub. For reference purposes, it is much easier to uninstall the sub box, remove the B&O subwoofer, install the new sub. The MB Quart has a much tighter response with a nicer thump. For $57 (Amazon) it was one of the best upgrades I've ever done.
I just finished doing this and I have to agree, best $57.00 spent in a long time. With a little dremel work I was able to put the original cover and trim ring back, it looks original. The dremel work was done to make the speaker fit flush.
You can use the original screws plus 6 extras and the sub is anchored. I also used about 8ozs of poly-fil, then connected the 2 pairs of wires, one pair into the left side, the other pair into the right side of the sub. I removed the pins from their plugs and just put them in the push lock connections on the sub, worked great, very secure. I did a test run and was surprised at the improvement. Using the original screws I installed the cover and then snapped the trim ring into place. GTG
The only difference from the original B&O subwoofer is that you see MB Quart on the cone through the sub cover. It is a slick install. The bass is tighter with a good thump, you can actually use the bass control and turn it up without distorting. A hell of a lot better then the original sub!
Lgb0250
NC/SC
Larry
22 Mustang GT Premium, 22 Lexus 450h Luxury
Had my new Steeda H-pipe installed. Very happy. Tried to post 10sec video but I’m tech challenged when it comes to these forums.
Rapid Red
Woodstock GA
Greg
New, 2000 miles. todays list, oil, filter, tire rotation, & tail pipe wrap around the carrier.
16Fastback
RMR 8985
Pennsylvania
Stephen
You're probably getting tired of seeing my carbon fiber updates but here's some more
NoVaGT
Northern Virginia
2019 PP1 GT Kona
Wait.....
You're having all 4 tires dismounted, and moving them from the front rims to rear, and vice-versa?
Is it work the hassle, when the tires last for such a short time?
Silveryote
Hiram,GA
Randy
2015 GT Premium
Installed a Velossatech Big Mouth Ram Air snorkel on my GT today. Also opened up the grill so it can flow freely into the intake track. You can see clearly into the intake box now. Hoping it'll help provide more and cooler much needed air.
Tang
South Florida
15 GT PP
How long did it take and did you have any help? Mine has been sitting in my closet for 2 years I bought in a group buy but never had a reason to take the front end off yet
