Ghost50
Houston by way of Philadelphia
2019 Magnetic Metallic GT PP1
UPR polyurethane motor mounts (dropping the engine 1/2”) going on today.
Voo Doo
Surrey BC
Ric
2019 BULLITT DHG
Added these Green Caps...cheap!! $3 !!
o-man
Durham, NC
Oscar
2019 Ford Mustang Bullitt
Washed it and loaded tires in back for an autocross tomorrow
Ghost50
Done.
Noticeable drop when looking at this angle and from the side.
Initial impression...very nice. Slack has been removed from the shifting and it only helped to solidify the driveline. Coupled with the other mods I have I’m liking it.
Completely worth the $159.
Labor took a little over an hour with it on a lift.
GMB Racing
nh
15 GT, 16 Escape, 21 F250 (all Ruby Red)
Make sure you use anti sieze on the threads those caps sieze on pretty quick. then you have to replace the stem. and that is not cheap, Don't ask me how I know but a little anti seize sure will help
HoosierDaddy
Randy
2016 GT Premium PP
And make sure you don't add air within sight of strangers lest some do-gooder tackles you to prevent contamination of your pure nitrogen. Don't ask me how I know.
GT Pony
Pacific NW
I finished up the install of Sullivan Racing Pedals on my 2017 GT. No more slippery clutch pedal. Heel toe like a boss.:like:
Did you have to remove the stock pedal covers before installing these?
samd1351
Olathe, KS
Sam
2017 Mustang GT, 1999 Ranger
Ordered a bunch of stuff from Anchor Room. Now the waiting begins. We'll see how it turns out.
Rover
So Cal Temecula
Scotty
2017 Mustang GT , Porsche Boxster S, BMW X5d, FORD Transit Diesel, 2500 Ram Diesel, Mazda CX5
Yes the clutch and brake covers simply peeled off with a little strong finger force. The gas pedal is held on with a 25mm torques bolt.
I suggest this is not a beginner mod as drilling the clutch and brake pedals is a bit tricky and the gas pedal should be removed once you decide where or how you will place the new cover.
I determined the new gas pedal could go 1/4 inch below and right of the base pedal (once the OEM foot pedal trim was removed) I set it up on the workbench and saw the Sullivan gas pedal had too much arch for my position. IT would have fit nicely if hanging down 1/2 to 3/4 inch but IMHO that would have hit the floor with my added mats and risked a binding situation. So i simply pounded the Sullivan gas pedal to a lesser curve to fit my desired location. Anyway not what I call a first mod but doable and the new pedals are very grippy
frank s
san diego CA
www.fsheff.com
frank
Stang '19 Magnetic, EcoBoost™, Vert, MagneRide® PP
Final Final: Tried 7/16" split loom over the 5/16ths: Fits very nicely, still yet even more insulation. Good. (Almost Cool)
Final—I hope—chapter in the Hot Prop Rod Trivial Mods Drama:
Five-sixteenths split wire loom corrugated tubing fits the rod perfectly and has enough insulation properties to soften the painful impact of touching the hood prop rod when it is too hot to handle. Heat shrink tubing 14mm size fits over the loom tube and when shrunk secures the insulation's position on the rod The position is important because the bare sections of the rod lie very close to the radiator cover; the insulated, shrunk part can be accommodated in a depression between the end sections. I put a small piece of the corrugated tubing over the bearing part of the J/L section that anchors the rod to the car, eliminating some slop in that area.
Blue Moon
Maine, or eastern Canada
Pete
17 Ecoboost Perform Pack Std
Ooh, thanks for the reminder. I still haven't put summer air in my tires.
Boston23
South Carolina
Bruce
2017 GT PPP Ingot Silver
Yes, the OEM clutch and brake pedal will pull off. Work one corner and the rest will come off easily. For the accelerator pedal, remove the three anchor nuts and disconnect the harness.
