Water-Methanol Injection
Zrussian13
Phoenix
I assure you it's not too small... It is a 24 gal/hr: Since I got spacers the Temps move a lot slower than it used to. Now, I do get -KnockR all the way up to 8000. I have a breakout, it's in the Rear of the supercharger.
That's a shit ton of meth!
wish i was fast
california
mike
2015 mustang gt s550
so your running .4 gallons per minute. that's almost a half a gallon a minute. are you sure about that?
illtal
YES ... I have the other BIGGER nozzle here all which where labeled in gal/hr. now they are labeled in orifice size, which is harder to tell what's going on with them.
Cory S
Bradford, NH
Cory
2016 Mustang GT Premium
.4/minute isn't THAT much. It's about the proper amount of volume/flow for 60-80% Methanol on a setup making 750-900whp. I used to run 28GPH @ 140psi system pressure for 780whp.
illtal
1 gal/hr is 63 cc .... which is 1512, which isn't even 10% of total fuel available to the system.
Cory S
Bradford, NH
Cory
Cory S
Bradford, NH
Cory
Cory S
Bradford, NH
Cory
but we are talking almost a half a gal a minute. not hour
Do you realize how much fuel at WOT can be consumed for an entire minute with setups making 700+whp? A LOT......... :)
wish i was fast
california
mike
Don't know about your calc. But one gal/hr is 63 cc/min. 24*63
OK not sure your point but they did not say they were running .4/gal per hour they said .4/ per minute. 24/gal per hour. almost half a gallon per minute.
illtal
What's your point?
I stated that I run a 24 gallon per hour nozzle, not they, I did. @Cory S stated he ran a 28 gallon per hour nozzle. Do you realize the line pressure dictates flow? It could be more or less. Next point is that I have yet to spend an entire minute boosted in the throttle.
You're weird. You do realize that there are conversion factors and different units of measurements especially for measurements over time. Things can tend to end up the same even if you don't realize that.
Example one. I buy a 1000cc injector. It is labeled as 1000cc a min. It is also labeled 95 lbs a hr. Question for you is which one is more?
Example two 1 mile per hour is equal to .447 meters a second.
BACK TO THE UPPER INJECTORS. 8 - 1000 CC injectors is equal to 127 gallons per hour. Do your own comparison to the water meth availability.
wish i was fast
california
mike
What's your point?
i had no problem with any of your debate tell you decided that since you don't see my point you felt that somehow you are entitled and since you can't understand then i must be weird. maybe your point was correct maybe not. but it doesn't matter because your character it far from correct. you could have said the same thing but you felt by making it personal you somehow are right? character, you should try some.
