Vortech / Paxton Official Tech Discussion Thread
beefcake
Bethel
2018 Ford Mustang
Wanted to get a thread going that guys and gals needing help or have questions or anything can have everything in one place. We'll also try to update info for different things that may be relevant to customers as well.
This is and has continued to be the vest value package out there and at this point we have thousands of cars running the kits.
Any customers that have done any kind of customizing, and things you may have changed are welcomed as well.
For the first links
I am going to put in the installation guides for the S550.
15-17 GT Paxton
https://cdn.shopify.com/s/files/1/0....1_INSTR_MAN_2015-17_MSTG_GT.pdf?v=1632412489
15-17 GT Vortech
https://cdn.shopify.com/s/files/1/0...TR._MAN_2015-17_FORD_MUST_GT.pdf?v=1632412167
18-23 GT Paxton
https://cdn.shopify.com/s/files/1/0780/8575/files/4809667v1.7_INSTR_MAN_18-20_MSTG_GT.pdf?680
18-23 GT Vortech
https://cdn.shopify.com/s/files/1/0780/8575/files/4FQ020-025v1.7_INSTR_MAN_18-20_MUST_GT.pdf?678
18-23 GT Vortech / Paxton Tuner Kit
https://cdn2.shopify.com/s/files/1/...AN_COMPETITION_TUNER_KIT_2018_MUST_GT.pdf?547
16-20 GT350 Vortech
https://cdn.shopify.com/s/files/1/0...4_INSTR._MAN_2016_MUST_GT350.pdf?v=1632412332
illadvised
San Diego
Brian Spilner
2015 GT - 6R80 - Paxton 2200SL
You know what is annoying about the paxton install instructions? I didn't see anything in there about installing the oil drain hose for the 2200SL kits
Got all the way done with my first centri install and had this random leftover hose with no explanation of what it is used for. Now I drain it from the top with a pump
Is it easy to add while the blower is installed on the car?
beefcake
beefcake
Bethel
2018 Ford Mustang
I wouldn't install until its time to drain, next time your draining, you can pull the plug and put it on
i'll review instructions and sent a note to vortech / paxton on it
Ruby17
Nashville
Chuck
2017 GT convertible
I ran into same issue. I've always just stuck a small hose down thru the top and pumped the oil out. So far no issues.
beefcake
beefcake
Bethel
2018 Ford Mustang
Next time you drain it to do an oil change you can pull the plug and put the drain line in.
tuf50L
Australia
Order pending
Might be worth clarifying the different compressor sizes and HP limits, pulley sizes for pump or E85, recommended injectors for fuel types?
beefcake
beefcake
Bethel
2018 Ford Mustang
SuperchargerGear
case
Max SpeedMax BoostMax FlowMax PowerPeak Eff.Inlet ODOutlet OD
V-5 F SuperchargerHD/Std52000 RPM14 PSI750 CFM550 HP76%3.5"2.5"
V-5 G SuperchargerHD/Std52000 RPM15 PSI750 CFM550 HP73%3.5"2.5"
V-9 F SuperchargerHD/Std52000 RPM13.5 PSI750 CFM550 HP72%3.5"2.5"
V-9 G SuperchargerHD/Std52000 RPM14 PSI825 CFM600 HP74%3.625"2.5"
V-3 H67B SuprechargerStd52000 RPM14 PSI750 CFM525 HP71%3.5"2.5"
V-1 S SuperchargerStd50000 RPM20 PSI1000 CFM680 HP72%3.5"2.75"
V-1 SC SuperchargerStd53000 RPM20 PSI1000 CFM680 HP75%3.5"2.75"
V-2 S SuperchargerStd50000 RPM20 PSI1000 CFM680 HP72%3.5"2.75"
V-2 SC SuperchargerStd53000 RPM20 PSI1000 CFM680 HP75%3.5"2.75"
V-1 SCi SuperchargerHD58000 RPM21 PSI1050 CFM725 HP75%3.5"2.75"
V-2 SCi SuperchargerStd53000 RPM17 PSI1050 CFM725 HP75%3.5"2.75"
V-3 SCi SuperchargerStd53000 RPM17 PSI1050 CFM725 HP75%3.5"2.75"
V-1 Si SuperchargerHD55000 RPM26 PSI1150 CFM775 HP78%3.5"2.75"
V-2 E SuperchargerStd52000 RPM17 PSI1150 CFM775 HP76%3.63"2.75"
V-2 Si SuperchargerStd52000 RPM22 PSI1150 CFM775 HP78%3.5"2.75"
V-3 Si SuperchargerStd52000 RPM22 PSI1150 CFM775 HP78%3.5"2.75"
V-1 Ti SuperchargerHD55000 RPM26 PSI1400 CFM950 HP75%3.75"2.75"
V-7 JT SuperchargerHD60000 RPM27 PSI1450 CFM1000 HP75%4"3.0"
V-4 J SuperchargerHD58000 RPM28 PSI1600 CFM1100 HP74%5"3.5"
V-27 YSi SuperchargerV-2065000 RPM30 PSI1600 CFM1200 HP78%4"3.0"
V-7 YSi SuperchargerHD65000 RPM30 PSI1600 CFM1200 HP78%4"3.0"
V-24 X SuperchargerV-2064000 RPM29 PSI1800 CFM1300 HP79%5"3.5"
V-4 X SuperchargerHD58000 RPM29 PSI1700 CFM1300 HP79%5"3.5"
V-4 XX SuperchargerHD64000 RPM29 PSI1950 CFM1400 HP78%5"3.5"
V-24 Z SuperchargerV-2060000 RPM32 PSI2000 CFM1450 HP77%5"3.5"
V-4 Z SuperchargerHD60000 RPM32 PSI2000 CFM1450 HP77%5"3.5"
V-24 Xi SuperchargerV-2064000 RPM29 PSI2300 CFM1600 HP79%5"3.5"
V-24 XB105 SuperchargerTBA69000 RPM35 PSI2900 CFM1700 HP75%5"3.5"
V-21 XB110 SuperchargerTBA65000 RPM35 PSI3100 CFM1900 HP73%6"3.5"
V-28 123 SuperchargerV-2060000 RPM45 PSI4000 CFM2800 HP83%6"4.0"
Paxton Supercharger Specification Chart
SuperchargerGear
case
Novi 120052000 RPM22 PSI1150 CFM775hp3.50″2.38″
Novi 1200SL52000 RPM22 PSI1150 CFM775hp3.50″2.38″
Novi 122053000 RPM17 PSI1050 CFM725hp3.50″2.38″
Novi 1220SL53000 RPM17 PSI1050 CFM725hp3.50″2.38″
Novi 150055000 RPM26 PSI1200 CFM950hp3.75″2.75″
Novi 1500SL55000 RPM26 PSI1200 CFM950hp3.75″2.75″
Novi 200055000 RPM26 PSI1400 CFM970hp4.00″2.60″
Novi 2000 Race55000 RPM26 PSI1400 CFM970hp4.00″2.60″
Novi 220060000 RPM27 PSI1000 CFM1000hp4.00″3.00″
Novi 2200SL60000 RPM27 PSI1000 CFM1000hp4.00″3.00″
cbrtrx
tampa fl
2016 mustang gt
I think that list needs to be updated the V3 JT is not on there. V7 JTB isn't either.
beefcake
beefcake
Bethel
2018 Ford Mustang
SupremeFocus
Los Angeles
19 GT PP1 10R80
I have the vortech kit with 6 rib 102” belt anyone know what gates green belt I need. What’s a part # thanks.
Nawsad123
Everett
Bonez
2017 Mustang GT
How can I think of max boost on each blower above? Currently have a V3si and I am maxed out at 12 psi'ish or so pushing 720 rwhp on race gas. Cant throw anymore boost at it as I will be over spinning the blower. Pretty sure im maxed out from a power stand point unless im missing something?
beefcake
beefcake
Bethel
2018 Ford Mustang
K061020HD
you can use the chart here
https://vortechsuperchargers.com/pages/impeller-speed-calculator
stock balancer on a coyote is 6.78"
beefcake
beefcake
Bethel
2018 Ford Mustang
you use 6.78
