Voodoo short block with gen 3 heads
robvas
MI
2011 GT
From my understanding is lunds grey goose has a boss 302 crank but uses voodoo heads and cams
according to a YouTube video from three months ago:
FFRE Long Block GT350 heads w/ Ford Performance 5.2 Cams and intake only VCT
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
It will not work. If you want to try it I can almost guarantee you will hit the valves with a piston.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
No they do not! Ford actually has a part number for the correct cams to use for a cross plane crank and Voodoo heads. I believe they are the same specs as the Voodoo cams but cut for cross plane use and firing order.
I'm pretty sure those are discontinued. MHS can cut the OP a set tho.
engineermike
La
2018 GTPP A10
Predator 5.2 crank is available from FP and could fix the compatibility issue. I’m sitting here looking at a predator 5.2 short block with gen3 heads and cams….
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Yep that works.
rolfe.oliver
St. Louis, MO
Oliver
1967 Mustang GT350 Tribute, 1971 Mustang Mach 1
FFRE short block, which I believe is a Boss crank, GT350 heads with Predator cams, VCT on Exhaust is locked, VCT active on Intake cam.
